HP Z220 Workstation SFF Intel Core i3-3240 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: 8MSFWS00 Mfr#: WM497ET#ABU
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
Get workstation performance with next-generation graphics at prices you'd expect from a desktop PC. Available as a Convertible Minitower or a Small Form Factor, HP offers the enterprise-class design that fits you best.
  • Designed to fit your business
    Choose the expansive Convertible Minitower or the space-saving Small Form Factor design – both complete with tool-free chassis that make adding hard drives and upgrading memory a snap.Take advantage of world class architecture with the latest in connectivity for external storage devices and peripherals. Transfer data 10x faster than USB 2.0 ports with four integrated super-speed USB 3.0 ports.Business-built and environmentally aware – featuring a 90% efficient power supply, low halogen configurations and your choice of ENERGY STAR qualified configurations.
  • High performance, no sweat
    Increase performance and reduce energy consumption with next-generation 22nm processors, including the Intel Xeon processor E3-1200v2 family and 3rd-generation Intel Core processors.Give memory intensive applications a boost with 1600 MHz DDR3 memory technology and support for ECC memory configurations to help protect your data integrity.Keep going at a moment's notice with Intel Smart Response Technology, a disk cache solution that provides solid state drive like performance, faster boot up times and quick application responsiveness.Optimize your output with integrated HP Performance Advisor. Run reports, diagnose and fine-tune your workstation specific to your professional applications with just one click.
  • Next-generation graphics
    Take presentations to the next level and bring work to life with integrated Intel HD Graphics.Access your high-performance 2D, 3D, video and media-rich applications regardless of where you are. Preinstalled HP Remote Graphics Software gives you the freedom to work remotely without skipping a beat.Be ready with the bandwidth you need for tomorrow's generation of PCIe 3D graphics cards from NVIDIA and AMD the moment they're available.
HP Workstation Z220 - SFF - Core i3 3240 3.4 GHz - 4 GB - HDD 500 GB
Workstation - small form factor - system password, power-on password, serial port I/O control, USB port control, audio ports control, network port control
1 x Intel Core i3 (3rd Gen) 3240 / 3.4 GHz (Dual-Core)
Processor Socket
LGA1155 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SATA (SATA 6Gb/s); SATA (SATA 3Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 2500
Audio Output
Integrated
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Intervideo WinDVD, HP ProtectTools Security Manager, Roxio Easy Media Creator, HP Support Assistant, HP Power Assistant, PDF Complete (Trial), HP Performance Advisor
Jack black
33.8 cm x 38.1 cm x 10 cm
7.5 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Workstation
Recommended Use
Small business, corporate business
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Jack black
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1155 Socket
Chipset Type
Intel C216
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total)
Unbuffered
RAM Supported
32 GB unbuffered - ECC , 32 GB unbuffered - non-ECC
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
RAID Level
RAID 0, RAID 1
Storage Controller (2nd)
SATA 3Gb/s
Channel Qty
2
RAID Level
RAID 0, RAID 1
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Keyboard
PS/2
Mouse
Laser
USB
Integrated
Ethernet Controller
Intel 82579LM
Wake on LAN (WoL), PXE support
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x external 3.5"
Slots
1 (total) / 0 (free) x CPU , 4 DIMM 240-pin , 1 (total) / 1 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCI - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode)
6 x USB 2.0 (4 front, 2 rear) , 4 x USB 3.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x serial , 1 x DisplayPort , 1 x VGA
System password, power-on password, serial port I/O control, USB port control, audio ports control, network port control
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI 2.0, RoHS, WEEE
HP Smart Buy
Power supply
Power Provided
240 Watt
80 PLUS Certification
80 PLUS Gold
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
33.8 cm
38.1 cm
10 cm
7.5 kg
5 °C
35 °C
8 - 85% (non-condensing)
