HP Z2 G4 Core i7-8700K 8GB 1TB Windows 10 Pro
Quicklinx: DQHKWS00 Mfr#: 4RW91EA#ABU
  • Core i7
Get next-level performance with a compact device that can easily handle single and multi-threaded applications. With nearly endless configuration options, the Z2 SFF is the perfect hardware solution for your customization needs.
  • Windows 10 Pro 64
    Work without compromising on performance or security with Windows 10 Pro, powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
  • Smaller, Functional Design
    The stunning new design features front and rear ledges, so you can easily move your system from location to location.
HP Workstation Z2 G4 - SFF Core i7 8700 3.2 GHz - vPro - 8 GB - HDD 1 TB - UK
Workstation - SFF
Platform Technology
Intel vPro Platform
1 x Intel Core i7 (8th Gen) 8700 / 3.2 GHz (up to 4.6 GHz, (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel UHD Graphics 630 Dynamic Video Memory Technology 5.0
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
33.8 cm x 38.1 cm x 10 cm
5.5 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
SFF
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
4.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C246
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered
Configuration Features
2 x 4 GB
RAM Supported
64 GB unbuffered - ECC , 64 GB unbuffered - non-ECC
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), ACPI support, PXE support, Intel Active Management Technology (AMT) 12
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x4 - low-profile (x1 mode) , 2 (total) / 2 (free) x M.2 Card - low-profile (x4 mode) , 1 (total) / 1 (free) x M.2 Card - low-profile (x1 mode)
6 x USB 3.0 (2 front, 4 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 2 x DisplayPort , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, WEEE
Power Provided
250 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
33.8 cm
38.1 cm
10 cm
5.5 kg
Shipping Width
22.9 cm
Shipping Depth
51.8 cm
Shipping Height
49.9 cm
Shipping Weight
9.35 kg
5 °C
35 °C
10 - 85% (non-condensing)
Warranties (1)
DQHK HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site In Stock £32.99
Other bundles (2)
DQHK HPE DisplayPort DVI-D Adapter In Stock £11.55
DQHK HPE DisplayPort to VGA Adapter In Stock £13.38
