HP Z2 G3 Mini Xeon E3-1225V5 16GB 256GB SSD Windows 10 Pro
Quicklinx: DVCMWS00 Mfr#: 2WU06ET#ABU
Processor Type: Xeon
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Xeon
£1,336.38 ex VAT
£1,603.65 inc VAT
Finally a revolutionary mini PC for CAD that delivers breakthrough power and versatility in a small, elegant design. Made by and for design professionals, the Z2 Mini gives you both performance and reliability for the best CAD experience.
  • Next-level power
    Get server-grade power in a remarkably small device. Intel Xeon processorsand NVIDIA Quadro graphics keep up with the speed of your creativity.
  • Designed for the workspace of the future
    We packed workstation performance into a mini PC with a design that will turn heads. Our most flexible and most beautiful workstation ever-perfect for every office environment.
  • Industry-leading reliability
    Tech issues should never hold you back. The Z2 Mini is tested for 368,000 hours and certified for the most popular CAD software. Feel confident using a workstation influenced by over 30 years of engineering and backed by a 3-year standard limited warranty.
HP Workstation Z2 Mini G3 Performance - mini - Xeon E3-1225V5 3.3 GHz - 16 GB - 256 GB - UK
Workstation - mini
Platform Technology
Intel vPro Technology
1 x Intel Xeon E3-1225V5 / 3.3 GHz (3.7 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB - PCI Express - M.2 2280 - HP Z Turbo Drive
Optical Storage
No optical drive
Graphics Controller
NVIDIA Quadro M620 / Intel HD Graphics P530
Video Memory
2 GB GDDR5 SDRAM
Audio Output
Stereo
GigE
Keyboard
OS Provided
Space grey with black chrome accents
21.6 cm x 21.6 cm x 5.8 cm
2.04 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
Product Form Factor
Mini
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Unbuffered
Configuration Features
2 x 8 GB
RAM Supported
32 GB unbuffered - ECC , 32 GB unbuffered - non-ECC
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
HP Z Turbo Drive
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video Interfaces
DisplayPort
Max Monitors Supported
6
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Laser
USB
Ethernet Controller
Intel I219-LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode)
4 x USB 3.0 (2 front, 2 rear) (one of them is charging) , 2 x USB-C 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , 4 x DisplayPort , 1 x headphones/microphone (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
Power adapter
Nominal Voltage
Power Provided
200 Watt
Efficiency
89% (230VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
21.6 cm
21.6 cm
5.8 cm
2.04 kg
5 °C
35 °C
8 - 85%
Storage Type: SSD
Processor Model: E3-1225V5
Type: Workstation
Case Style: Ultra small form factor
Display: not included
Optical Storage: None
Brand: HP
Price Range Ex VAT: 1000 - 1500
