HP Z2 G3 Mini Xeon E3-1225V5 16GB 256GB SSD Windows 10 Pro
Quicklinx: DVCMWS00 Mfr#: 2WU06ET#ABU
  • Xeon
Finally a revolutionary mini PC for CAD that delivers breakthrough power and versatility in a small, elegant design. Made by and for design professionals, the Z2 Mini gives you both performance and reliability for the best CAD experience.
  • Latest Operating Systems
    Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems.
  • Intel Xeon /Core Processors
    Current and next generation Intel Core and Intel Xeon processor options for powerful workstation-class performance.
  • NVIDIA Quadro Pro Graphics
    Powerful M620 professional graphics from NVIDIA for your more demanding 3D models.
  • HP Z Turbo Drive
    Reduce boot up, file loading, and response times by revolutionizing how your Z2 Mini handles large files with up to 1.5 TB of storage with the optional HP Z Turbo Drive for a remarkably fast and innovative solution.
  • Remarkably Small
    At only 5.8 cm (2.3") high the Z2 Mini fits into any office environment.
  • Designed for designers
    Stylish and sleek. It's what a CAD PC should be.
HP Workstation Z2 Mini G3 Performance - mini - Xeon E3-1225V5 3.3 GHz - vPro - 16 GB - SSD 256 GB - UK
Workstation - mini
Platform Technology
Intel vPro Platform
1 x Intel Xeon E3-1225V5 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express - M.2 2280 - HP Z Turbo Drive
Optical Storage
No optical drive
Graphics Controller
NVIDIA Quadro M620 / Intel HD Graphics P530
Video Memory
2 GB GDDR5 SDRAM
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Space grey with black chrome accents
21.6 cm x 21.6 cm x 5.8 cm
2.04 kg
Manufacturer Selling Program
HP Smart Buy
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
16 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Unbuffered
Configuration Features
2 x 8 GB
RAM Supported
32 GB unbuffered - ECC , 32 GB unbuffered - non-ECC
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express
HP Z Turbo Drive
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video Interfaces
DisplayPort
Max Monitors Supported
6
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Laser
USB
Ethernet Controller
Intel I219-LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode)
4 x USB 3.0 (2 front, 2 rear) (one of them is charging) , 2 x USB-C 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , 4 x DisplayPort , 1 x headphones/microphone (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
HP Smart Buy
Power adapter
Power Provided
200 Watt
Efficiency
89% (230VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
21.6 cm
21.6 cm
5.8 cm
2.04 kg
5 °C
35 °C
8 - 85%
