HP Z1 Intel® Xeon® Processor E3-1245, 4GB, 160GB, DVD±RW, Windows 7 Professional 64-Bit
Quicklinx: 899BWS00 Mfr#: WM479EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Xeon
  • IEEE 802.11n
Introducing power without the tower. The new HP Z1 is the world's first all-in-one workstation featuring a 68,6 cm (27") diagonal display that snaps open to let you swap out parts and make upgrades . No tools required . Unleash your creativity with accelerated performance, 68,6 cm (27") LED-backlit display that supports over a billion colors , and HP's world-class reliability. The HP Z1. Advanced design from A to Z.
  • Open the display
    Get the simplicity of an all-in-one design, the power of a workstation, and the beauty of a 68,6 cm (27") display . Upgrade or add a hard drive, graphics card, or memory by snapping it open. And enjoy the control of easily swapping out parts on your own.With whisper quiet acoustics, you get high-performance with no distraction. Have face-to-face meetings and capture HD-quality video with the built-in HD webcam . Plus take advantage of SRS Premium Sound to give your work the high-quality audio it deserves.
  • Workstation performance without compromise
    Get the only all-in-one workstation featuring a 68,6 cm (27") diagonal display with quad-core Intel Xeon processors . And stay one step ahead of your imagination.Your most important work deserves the best memory. Avoid single-bit memory errors, help preserve data integrity, and make system crashes a thing of the past with supported EEC memory.
  • High performance graphics
    Use professional NVIDIA Quadro graphics for blazing fast rendering and performance, and spend more time being your creative best.See your work clearly on a 68,6 (27") diagonal LED-backlit IPS display that supports over a billion colors . With a wide, 178 degree viewing angle and an IPS panel, it's professional any way you look at it.
  • Build the machine you want to drive
    Choose from a variety of storage types, including 7.2K and 10K SATA, SSD, or optional RAID configurations. Always be confident you have the tools to get the job done.A professional workstation calls for a variety of I/O choices, including internal and external PCI Express slots, and USB 2.0 and 3.0 for blazing fast speeds.
  • World-class reliability from HP
    We design systems to be fundamentally more reliable. Then we rigorously test and optimize components to ensure it. Whether it is graphics cards, memory, or operating systems, you're able to focus on your projects, not your machine.With thoroughly tested and certified hardware and software combinations, you'll enjoy peace of mind knowing the tools you demand will work when you need them.
HP Workstation Z1 - all-in-one - Xeon E3-1245 3.3 GHz - vPro - 4 GB - SSD 160 GB - LED 27"
Workstation - all-in-one - system password, power-on password, USB port control, chassis intrusion detection
Platform Technology
Intel vPro Platform
1 x Intel Xeon E3-1245 / 3.3 GHz (3.7 GHz) (Quad-Core)
Processor Socket
LGA1155 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s / SATA 3Gb/s)
Hard Drive
SSD 160 GB
Optical Storage
DVD SuperMulti
Card Reader
4 in 1
Monitor
27" - LED - 2560 x 1440 - 16:9
Graphics Controller
MXM 3.0 Type A - NVIDIA Quadro 500M
Video Memory
1 GB DDR3 SDRAM
Audio Output
Integrated
GigE, Bluetooth, 802.11a, 802.11b/g/n
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Intervideo WinDVD, Roxio Easy Media Creator, HP Support Assistant, Microsoft Office 2010 Starter, PDF Complete (Trial), HP Performance Advisor
66.04 cm x 41.91 cm x 58.42 cm
21.32 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Platform Technology
Intel vPro Platform
Workstation
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Intel Xeon E3-1245
Clock Speed
3.3 GHz
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1155 Socket
Chipset Type
Intel C206
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1333 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total)
Unbuffered
RAM Supported
PC3-12800 - 8 GB unbuffered - non-ECC , PC3-12800 - 32 GB unbuffered - ECC
Hard Drive
SSD
1 x 160 GB
Storage Controller
1 x SATA - integrated
Controller Interface Type
Channel Qty
3
RAID Level
RAID 0, RAID 1
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
24x (CD) / 8x (DVD)
Card Reader
4 in 1 card reader
Monitor
Monitor Type
LED
Diagonal Size
27"
Native Resolution
2560 x 1440
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Colour Gamut
100% sRGB (CIE 1931), 77% NTSC (CIE 1931), 96% NTSC (CIE 1976)
Pixel Pitch
0.2331 mm
Response Time
12 ms
Image Brightness
380 cd/m²
Image Contrast Ratio
1000:1
Graphics Controller
Plug-in card
Interface Type
MXM 3.0 Type A
Graphics Processor
NVIDIA Quadro 500M
Video Memory
1 GB DDR3 SDRAM
Video Interfaces
DisplayPort
Audio Output
Integrated
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Integrated
Resolution (MP)
2 Megapixel
Input Device
Mouse, keyboard
Keyboard
Wireless
Mouse
Wireless
Audio Input
Stereo microphone
Ethernet Controller
Intel 82579LM
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Remote Management Protocol
DMI
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az
Bays
Internal 2 x 2.5"/3.5" shared
Slots
1 (total) / 0 (free) x CPU , 4 DIMM 240-pin , 1 (total) / 0 (free) x MXM (x16 mode) , 3 (total) / 2 (free) x PCIe 2.0 Mini Card
2 x USB 3.0 , 1 x FireWire , 1 x headphones , 1 x audio line-in/microphone , 1 x DisplayPort , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (subwoofer) , 1 x TOSLINK , 1 x audio line-in , 1 x audio line-out
System password, power-on password, USB port control, chassis intrusion detection
Theft/Intrusion Protection
RoHS, WEEE
Power supply
Power Provided
400 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
66.04 cm
41.91 cm
58.42 cm
21.32 kg
5 °C
35 °C
8 - 85% (non-condensing)
