HP Z1 G9 Intel Core i7-12700 16GB 512GB SSD Windows 10 Professional 64-bit
Quicklinx: H001WS00 Mfr#: 5F0G0EA#ABU
  • Core i7
Pro-grade performance is now within reach with a desktop built for designing, editing and even gaming. From 2D and 3D CAD to entry VR content creation, gain speed and efficiency across your workflows. Go beyond a commercial PC with a desktop certified for select professional software applications.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
HP Z1 G9 - tower - AI Workstation - Core i7 12700 2.1 GHz - vPro Enterprise - 16 GB - SSD 512 GB - UK
Workstation - tower - AI Workstation
Platform Technology
Intel vPro Enterprise
1 x Intel Core i7 (12th Gen) 12700 / 2.1 GHz (up to 4.9 GHz, (12-core)
Processor Main Features
Intel Turbo Boost Max 3.0
Cache Memory
25 MB L3 Cache
Cache Per Processor
25 MB
RAM
16 GB (installed) / 128 GB (max) - DDR5 SDRAM
Storage Controller
SATA
Hard Drive
SSD 512 GB - PCI Express - M.2 2280 - NVM Express (NVMe), HP Value
Optical Storage
No optical drive
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
NVIDIA GeForce RTX 3060 / Intel UHD Graphics 770
Video Memory
12 GB GDDR6 SDRAM
1GbE
Keyboard
(50/60 Hz)
OS Provided
Windows 10 Pro 64-bit Edition (downgrade from Windows 11 Pro) + Windows 11 Pro Licence
Software Included
HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Client Catalogue (free download), HP Setup Integrated OOBE, HP Notifications, HP Connection Optimizer, HP Privacy Settings, HP Cloud Recovery, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, myHP, HSA Fusion for Commercial, HSA Telemetry for Commercial, HP Desktop Support Utilities, HP Image Assistant Gen5 (free download), HP Easy Clean, HP Smart Support (free download), HP Manageability Integration Kit (free download), HP Patch Assistant (free download)
15.5 cm x 30.8 cm x 33.7 cm
6.15 kg
Environmental Standards
TCO Certified Desktops 9, ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
AI Level
AI Workstation
Product Form Factor
Tower
Sensors
HP Tamper Lock
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.1 GHz (P-core) / 1.6 GHz (E-core)
Max Turbo Speed
4.9 GHz (P-core) / 3.6 GHz (E-core)
Number of Cores
12-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 25 MB
Cache Per Processor
25 MB
RAM
Installed Size
DDR5 SDRAM
Effective Memory Speed
4800 MHz
Rated Memory Speed
4800 MHz
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2 2280
1 x 512 GB
Interface Type
PCI Express
Storage Controller
1 x SATA
Channel Qty
4
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Memory
12 GB GDDR6 SDRAM
Video Interfaces
HDMI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
USB
Localization & Layout
Mouse
Mouse Name
HP 320M
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
2 (total) / 2 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x PCIe 4.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x16 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 2 (total) / 1 (free) x M.2 Card - 2280 (x4 mode)
1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 3 x USB 3.2 Gen 1 , 4 x USB 3.2 Gen 2 (4 in front) (one of them is charging) , 1 x USB-C 3.2 Gen 2x2 (1 in front) (charging) , 1 x audio line-out/line-in , 2 x DisplayPort 1.4 , 3 x USB 2.0 (two of them with wake functionality) , 1 x LAN (Gigabit Ethernet) , 1 x HDMI
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington security slot
FCC Class B certified, ICES-003, RoHS, UL 60950-1, KCC Class B, Common Criteria EAL4+, CECP, VCCI Class B, SEPA, UL 62368-1, CAN/CSA-C22.2 No. 62368-1-14, CAN/CSA-C22.2 No. 60950-1-07
Power supply
AC 90-264 V (50/60 Hz)
Power Provided
550 watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
90% at 20% Load (115 VAC), 92% at 50% Load (115 VAC), 89% at 100% Load (115 VAC), 91% at 20% Load (230 VAC), 93% at 50% Load (230 VAC), 90% at 100% Load (230 VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
Software
Sustainability Information
TCO Certified
ENERGY STAR Certified
15.5 cm
30.8 cm
33.7 cm
6.15 kg
Shipping Width
40 cm
Shipping Depth
49.9 cm
Shipping Height
28.7 cm
Shipping Weight
8.87 kg
5 °C
35 °C
5 - 90%
Warranties (1)
H001 HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site In Stock £46.86
Monitors (1)
H001 HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £499.50
Other bundles (3)
H001 HPE DisplayPort DVI-D Adapter In Stock £19.88
H001 HPE DisplayPort to VGA Adapter In Stock £13.22
H001 HPE USB to Serial Port Adapter In Stock £13.95
