The HP Z1 G2 Workstation is HP's elegant and innovative all-in-one workstation with a large-screen display. Easily modify and change most components-no tools required. Unleash your creativity with accelerated performance and world-class reliability. Customize your display with optional 10-point touch technology in a stunning edge-to-edge glass design.
Spark creativity
Bring ideas to life faster than ever with the Intel Xeon processor, NVIDIA Quadro graphics, ECC memory and a wide range of ISV certifications.Be wowed and do more with features enabled by HP's cutting-edge engineering, including a high-end professional MXM Graphics cooling module, optional multiple hard drives and an adjustable custom display stand.Connect in a flash and strike productivity with optional high-performance Thunderbolt 2.0 ports located on the side of the HP Z1 G2 for easy accessibility.Take computing performance to another level with more efficient processing thanks to 4th generation Intel Core/Xeon E3 processors.A wide range of professional 3D graphics options from NVIDIA give you the confidence that you're working with the very best tools available. Or, choose Intel's new integrated graphics for the ultimate visual experience. -
Powerful and refined
Change most components or make upgrades on your own without tools or a service technician. Simply snap open the chassis and customize to fit your needs.Your most frequently used data is quickly accessible on the HP Z1 G2 Workstation with optional mSATA storage technology that provides fast storage and cache for OS and applications.Easily plug in devices to accessible I/O ports and enjoy the simplicity of push button display movement into and out of service mode on the HP Z1 G2 Workstation.Treat your ears to premium audio features on the HP Z1 G2 Workstation, including dual cone, front-facing speakers and DTS Studio Sound. -
Versatile view
Reach for success on the HP Z1 G2 Workstation with the optional 10-point touchscreen. Get creativity flowing and let your fingers fly over the stunning edge-to-edge glass display.Step into the light. Reduce reflection and work with clarity on the HP Z1 G2 Workstation with no-glass, anti-glare display.Your work never looked better. Let your ideas shine on the HP Z1 G2 Workstation Next Generation 68,6 cm (27') diagonal IPS display (2560x1440).
- HP Workstation Z1 G2 - all-in-one - Xeon E3-1226V3 3.3 GHz - vPro - 8 GB - SSD 256 GB - LED 27"
- Workstation - all-in-one - power-on password, USB port control, chassis intrusion detection, Intel Active Management Technology (iAMT), audio ports control, network port control, Setup Password
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Xeon E3-1226V3 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-14900
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s - mSATA
- Optical Storage
- DVD SuperMulti
- Card Reader
- Monitor
- 27" - LED - 2560 x 1440 - 16:9
- Graphics Controller
- Intel HD Graphics P4600 Dynamic Video Memory Technology
- Audio Output
- Stereo - integrated
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Software Included
- PDF Complete Corporate Edition, HP Performance Advisor, HP Remote Graphics Software 6
- 66.04 cm x 41.91 cm x 52.83 cm
- 21.32 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Recommended Use
- Small business, corporate business
- Product Form Factor
- All-in-one
- Built-in Devices
- Stereo speakers
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1226V3
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 1866 MHz
- Memory Specification Compliance
- PC3-14900
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 2 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 2 x 4 GB
- RAM Supported
- PC3-14900 - 16 GB unbuffered - non-ECC , PC3-14900 - 32 GB unbuffered - ECC
Hard Drive
- SSD - mSATA
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 27"
- Native Resolution
- 2560 x 1440
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 100% sRGB (CIE 1931), 77% NTSC (CIE 1931)
- Pixel Pitch
- 0.2331 mm
- Response Time
- 14 ms
- Image Brightness
- 380 cd/m²
- Image Contrast Ratio
- 1000:1
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Form Factor
- Integrated
- Resolution (MP)
- 2 Megapixel
Input Device
- Mouse, keyboard
Keyboard
- Connectivity
- Wireless
Mouse
- Connectivity
- Wireless
Audio Input
- Stereo microphone
- Ethernet Controller
- Intel I217-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 7260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Remote Management Protocol
- DMI
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac
- Bays
- 1 (total) / 1 (free) x internal 2 x 2.5"/3.5" shared
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 0 (free) x MXM 3.1 (x16 mode) , 2 (total) / 1 (free) x Mini PCIe 2.0/mSATA - full-length
- 2 x USB 3.0 , 1 x headphones , 1 x microphone , 1 x DisplayPort , 5 x USB 2.0 (4 rear, 1 internal) , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (subwoofer) , 1 x SPDIF output , 1 x audio line-in , 1 x audio line-out
- Power-on password, USB port control, chassis intrusion detection, Intel Active Management Technology (iAMT), audio ports control, network port control, Setup Password
- Theft/Intrusion Protection
- RoHS, WEEE, ACPI 4.0
- Power supply
- Voltage Required
- Power Provided
- 400 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Software
Sustainability Information
- ENERGY STAR Certified
- 66.04 cm
- 41.91 cm
- 52.83 cm
- 21.32 kg
- 5 °C
- 35 °C
- 8 - 85% (non-condensing)
