HP Z Turbo Drive G2 - SSD- 512 GB - internal
Quicklinx: CKMCWS00 Mfr#: M1F74AT
Super charge your productivity and creativity and deliver optimized HP Workstation workflows with the HP Z Turbo Drive G2 PCIe SSD, which delivers four times the read performance of traditional SSDs at a cost that's remarkably similar.
Faster than HP’s fastest.
Improve the way you work and get ultra-fast I/O response to process large data sets with the second generation HP Z Turbo Drive.
Customize your solution.
Easily expand your storage solution by integrating a high-performance HP Z Turbo Drive G2 PCIe SSD with high-capacity SATA HDDs and SSDs.
Low latency technology
Realize expanded performance gains in applications that require random access with new NVMe technology.
  • Faster than HP's fastest
  • Customize your solution
  • Low latency technology
HP Z Turbo Drive G2 - SSD - 512 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
512 GB
NAND Flash Memory Type
Multi-level cell (MLC)
M.2
PCIe 3.0 x4 (NVMe)
Half-height half-length form-factor
51 g
Manufacturer Selling Program
HP Smart Buy
Workstation Z1 G3, Z440, Z640, Z840
512 GB
M.2
PCIe 3.0 x4 (NVMe)
51 g
Performance
SSD Endurance
292 TB
Internal Data Rate
1.17 GBps (read) / 930 MBps (write)
4KB Random Read
122000 IOPS
4KB Random Write
72000 IOPS
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe)
Compatible Bay
M.2
Microsoft Windows 7, Windows 8
HP Smart Buy
70 °C
HP Workstation Z1 G3, Z440, Z640, Z840
