We built desktop workstation power, performance and expandability into a device designed for the road. Made for mobile creative and design professionals with the most demanding projects, where compromise is simply not an option.
Extreme power and expandability
Our most powerful mobile workstation is designed for demanding workloads. Configure your HP ZBook 17 with the latest Intel Xeon processors, NVIDIA Quadro or AMD Radeon Pro graphics, up to 4 TB of storage and dual Thunderbolt 3 ports. -
No compromise reliability
Confidently take on your workday with our durable & reliable HP ZBook 17. With a 3-year onsite limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
- HP ZBook 17 G4 Mobile Workstation - 17.3" - Intel Xeon - E3-1535MV6 - 32 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Xeon E3-1535MV6 / 3.1 GHz, up to 4.2 GHz / 8 MB Cache
- Memory
- 32 GB DDR4 (2 x 16 GB)
- Storage
- 512 GB SSD - SED, HP Z Turbo Drive, TCG Opal Encryption 2, NVMe, TLC
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P3000 / Intel HD Graphics P630
- Video Memory
- 6 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 6-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Space Silver
- 42 cm x 28 cm x 3.3 cm
- 3.14 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM238
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - ECC
- Speed
- 2400 MHz / PC4-19200
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - Self-Encrypting Drive, HP Z Turbo Drive, TCG Opal Encryption 2, NVM Express (NVMe), triple-level cell (TLC)
- RAID Level
- RAID 0, RAID 1
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 6 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus, Shader Model 5.0
- Camera
- Yes - 720p
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 720p HD movie recording, low light enhancement
- Sound
- Stereo speakers, two microphones
- Codec
- CX7501
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Wake-on-LAN (WOL), dual stream (2x2)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2
- Technology
- 6-cell Lithium Ion
- Capacity
- 96 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 200 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- VGA , HDMI , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 3.0 (charging)
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Fingerprint Software, Skype, LANDesk Management Suite, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Secure Erase, HP Security Manager, HP Manageability, CyberLink Power Media Player, HP Client Catalog, Absolute Persistence, HP Driver Packs, HP BIOS Config Utility, HP Touchpoint Manager, HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Workwise, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, Native Miracast
- Space Silver
- Case Material
- Aluminum, magnesium alloy
- Security
- HP 3D DriveGuard, HP DuraKeys, One-Step Logon, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+
- Localization
- 3.14 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE | In Stock | £33.61 |
Other bundles (10)
HPE HDMI to DVI Adapter | In Stock | £9.89 |
HPE DisplayPort to VGA Adapter | In Stock | £16.34 |
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB Travel Mouse | In Stock | £10.14 |
HP X4000b Bluetooth Mouse | In Stock | £28.71 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Premium Wireless Mouse | In Stock | £38.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
