Meet our thin and light HP ZBook 14u. This Ultrabook Workstation delivers an extraordinary level of power and graphics capability in a remarkably compact design. Now you can take workstation-class power anywhere you go.
Designed to move
Hit the road in style with our thin and light mobile workstation. At 22 mm thin, as little as 1.64 kg (3.61 lbs) and impressive features like a 35.56 cm (14") touch or 4K UHD display, you'll be ready to innovate from anywhere. -
Next-level power
Step-up to workstation-class power with 3D graphics, the latest Intel Core i5 and i7 processors, up to 32 GB memory and 2 TB of storage. Plus, it's certified with leading software partners for fast performance across multiple apps. -
No compromise reliability
Confidently take on your workday with our durable & reliable HP ZBook 14u. With a 3-year limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
- HP ZBook 14u G4 Mobile Workstation - 14" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD FirePro W4190M / Intel HD Graphics 620
- Video Memory
- 2 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Gigabit Ethernet
- Battery
- 3-cell - up to 10 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Space Silver
- 33.8 cm x 23.7 cm x 2.21 cm
- 1.64 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (7th Gen) 7500U / 2.7 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Full HD standard-viewing angle (SVA) anti-glare
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Video System Features
- AMD Enduro technology
- Camera
- Yes - 720p
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, two microphones
- Codec
- CX7501
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Miracast, Wake-on-LAN (WOL)
- Technology
- 3-cell lithium polymer
- Capacity
- 51 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x SIM card (1 free)
- Interfaces Details
- VGA , USB 3.0 (charging) , USB 3.1 Gen 1 , USB 3.0 , DisplayPort , Headphone/microphone combo jack , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Software
- Software Included
- Skype, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, HP Systems Software Manager (free download), HP Velocity, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Image Assistant (free download), HP JumpStart, HP JetAdvantage Connect, HP Noise Cancellation, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3
- Space Silver
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- HP 3D DriveGuard, HP DuraKeys, HP SpareKey, soft-touch surface, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen
- Localization
- 1.64 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
HP 90W Smart AC Adapter | In Stock | £21.86 |
HP 65W Smart AC Adapter | In Stock | £17.92 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £143.82 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £92.96 |
Other bundles (4)
HPE DisplayPort to HDMI Adapter | In Stock | £13.17 |
HPE DisplayPort to VGA Adapter | In Stock | £13.20 |
HP USB-C To VGA Adapter | In Stock | £22.09 |
HP USB Travel Mouse | In Stock | £9.39 |
