Be more productive on the go with the sleek, stylish HP X4000b Bluetooth Mouse that's comfortable wherever you work best and complements your HP Business Notebook, Ultrabook or tablet PC.
The compact, cordless design fits easily into a carrying case alongside your notebook, tablet or Ultrabook™.
The mouse works seamlessly with Bluetooth-enabled laptops, Ultrabook™ PCs, and tablets without taking up a valuable USB port. A helpful LED indicator light verifies your connection and alerts you when the battery runs low.
The high-precision 1600 dpi laser sensor works on most surfaces so you can stay productive wherever the day takes you. The rubber-edge grips make the mouse comfortable and easy to handle in either hand.
Life-enhancing productivity
The HP Bluetooth mouse X4000B not only looks stunning, it also improves your mobility. Advanced Bluetooth wireless keeps you connected even when you're on the go and the laser sensor works on most surfaces. -
Mind-blowing 9-month battery life
9 months is a very long time. Competitive models at the same price only last 4 and 3 short months. That adds up to the battery in the HP Bluetooth mouse X4000B lasting more than 3x as long. -
Blissful Bluetooth connection
This absolutely changes the navigation game. The HP Bluetooth mouse X4000B replaces the USB connection to save a port spot. Great news for tablet and Ultrabook users where extra USB ports are at an all-time premium.
- HP X4000B - mouse - Bluetooth
- Mouse
- Connectivity Technology
- Wireless - Bluetooth
- 6.71 cm x 10.69 cm x 3.86 cm
- 122.5 g
- Movement Detection Technology
- Laser
- Movement Resolution
- 1600 dpi
- Battery
- 2 x AA type
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista
- Mouse
- 6.71 cm
- 10.69 cm
- 3.86 cm
- 122.5 g
Input Device
- Wireless
- Interface
- Bluetooth
- Laser
- 1600 dpi
- 1 x USB
- AA type
- Installed Qty
- 2
- Run Time (Up To)
- 9 months
- OS Required
