HP X4000b Bluetooth Mouse
Quicklinx: CKL6WS00 Mfr#: H3T50AA#AC3
Recommended Use: Office
Type: Mouse
Wired / Wireless: Wireless
Colour: Ultimate black
Compatibility: PC
£28.71 ex VAT
£34.45 inc VAT
Be more productive on the go with the sleek, stylish HP X4000b Bluetooth Mouse that's comfortable wherever you work best and complements your HP Business Notebook, Ultrabook or tablet PC.
The compact, cordless design fits easily into a carrying case alongside your notebook, tablet or Ultrabook™.
The mouse works seamlessly with Bluetooth-enabled laptops, Ultrabook™ PCs, and tablets without taking up a valuable USB port. A helpful LED indicator light verifies your connection and alerts you when the battery runs low.
The high-precision 1600 dpi laser sensor works on most surfaces so you can stay productive wherever the day takes you. The rubber-edge grips make the mouse comfortable and easy to handle in either hand.
  • Life-enhancing productivity
    The HP Bluetooth mouse X4000B not only looks stunning, it also improves your mobility. Advanced Bluetooth wireless keeps you connected even when you're on the go and the laser sensor works on most surfaces.
  • Mind-blowing 9-month battery life
    9 months is a very long time. Competitive models at the same price only last 4 and 3 short months. That adds up to the battery in the HP Bluetooth mouse X4000B lasting more than 3x as long.
  • Blissful Bluetooth connection
    This absolutely changes the navigation game. The HP Bluetooth mouse X4000B replaces the USB connection to save a port spot. Great news for tablet and Ultrabook users where extra USB ports are at an all-time premium.
HP X4000B - mouse - Bluetooth
Mouse
Wireless - Bluetooth
6.71 cm x 10.69 cm x 3.86 cm
122.5 g
Movement Detection Technology
Laser
Movement Resolution
1600 dpi
2 x AA type
Microsoft Windows 7, Microsoft Windows Vista
Mouse
6.71 cm
10.69 cm
3.86 cm
122.5 g
Input Device
Wireless
Bluetooth
Laser
Movement Resolution
1600 dpi
1 x USB
AA type
Installed Qty
2
Run Time (Up To)
9 months
Type: Mouse
Compatibility: PC
Brand: HP
