Play longer, comfier, and with amazing accuracy on our suite of sweet curved gaming monitors. We've redefined high definition gaming with VA Panel Technology, 165Hz refresh rate, 1ms response time, and AMD FreeSync Premium.
Eyesafe Certified Display
Eyesafe certified displays meet TU¨V low blue light requirements and Eyesafe standards for protecting your eyes from harmful blue light without distorting colors to reduce eyestrain when working for long periods of time. -
Adjust your view
Adjust your screen for comfortable viewing with tilt capability. -
Sustainably Sourced Packaging
HP is innovating new ways to reduce the amount of materials in our packaging and to use more recycled materials in the design. -
VA panel
Get wide, 178-degree viewing angles and better black levels for deep, rich contrast. -
1,500R curved display
A dramatic curve delivers an incredibly realistic and immersive gaming experience. -
165Hz refresh rate
Crisp action and incredibly responsive gameplay with virtually no artifacting or screen tearing.
 - HP X32c Gaming Monitor - LED monitor - curved - Full HD (1080p) - 32"
 - LED-backlit LCD monitor - 32"
- Energy Class
 - Class F
- Energy Consumption per Year
 - 27 kWh
- Curved Screen
- Adaptive-Sync Technology
 - AMD FreeSync Premium
- Panel Type
 - VA
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 165 Hz
- Pixel Pitch
 - 0.3637 mm
- Brightness
 - 350 cd/m²
- Contrast Ratio
 - 3000:1 / 10000000:1 (dynamic)
- Response Time
 - 1 ms (MPRT with overdrive)
- Gaming
- Colour Gamut
 - 97% sRGB
- Input Connectors
 - HDMI, DisplayPort
 - Height, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating
- Voltage
 - AC 100-240 V (50/60 Hz)
 - 70.89 cm x 23.49 cm x 55.37 cm
 - 8.5 kg
- Localisation
 - English / United Kingdom
 - TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, IEC 60950-1, ISO 9241-307, KCC, WEEE, PSE Mark, cTUVus, CEC, KC, CECP, CEL, EAC, ISC, BIS, DisplayPort 1.4, ICE, NRCS, Mexico Energy label, Ukraine, UAE
- Display Type
- Energy Class
 - Class F
 - 27 kWh
- Diagonal Size
 - 32"
- Curved Screen
 - Yes (1500R)
- Panel Type
 - VA
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.3637 mm
- Pixel Per Inch
 - 70
- Brightness
 - 350 cd/m²
- Contrast Ratio
- Colour Gamut
 - 97% sRGB
- Response Time
- Vertical Refresh Rate
 - 60 - 165 Hz
- Horizontal Refresh Rate
 - 30 - 210 kHz
- Gaming
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - LED backlight
 - On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, Eyesafe technology, 8-bit Colour Depth, edge-lit LED backlight
 - 70.89 cm x 23.49 cm x 55.37 cm - with stand
 - 8.5 kg
 - DisplayPort 1.4 (HDCP) , HDMI (HDCP) , Audio line-out (mini-jack)
Mechanical
 - Height, tilt
- Tilt Angle
 - -5/+20
- Height Adjustment
 - 100 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
 - 1 x DisplayPort cable
- Localisation
- Security Slot Type
 - Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
 - 27 kWh/1000h
- Power Consumption (Typical)
 - 25 Watt
- Power Consumption (Max)
 - 50 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Included Software
 - HP OMEN Gaming Hub
- Dimensions & Weight Details
 - With stand - width: 70.89 cm - depth: 23.49 cm - height: 55.37 cm - weight: 8.5 kg , Without stand - width: 70.89 cm - depth: 9.47 cm - height: 42.55 cm
- Shipping Width
 - 95.5 cm
- Shipping Depth
 - 18.7 cm
- Shipping Height
 - 52.7 cm
- Shipping Weight
 - 13.4 kg
 - 5 °C
 - 35 °C
 - 20 - 80% (non-condensing)
