Built with strict standards and guidelines, the HP Mouse X3000 effortlessly blends sleek, modern design with life-enhancing, advanced features.
Premium HP standards
70 years experience. Strict quality control. 1 of the world's leading notebook manufacturers. HP delivers cutting-edge products built with some of the industry's toughest standards to enhance the way you connect & communicate. -
Stylish, attractive design
The sleek and modern HP Mouse X3000 adds an instant touch of trend-setting style to any work space. Glossy black and metallic gray shine with sophistication. Plus, its curvy silhouette gives it a seductive shape. -
Updated, enhanced specs
The HP Wireless Mouse X3000 features the latest technology you crave. 2.4GHz wireless connection sets you free. Battery life lasts 12 months.(1) Scroll wheel flies through the web and documents. Optical sensor works on most surfaces. -
Scroll wheel
Zips you through the web and documents with speed & ease.
- HP X3000 - mouse - 2.4 GHz - metallic grey, glossy black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Metallic grey, glossy black
- 5.7 cm x 9.485 cm x 3.911 cm
- 80 g
- Localisation
- English / Europe
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1200 cpi
- Scrolling wheel
- Battery
- 2 x AA type
- 2-year warranty
- Mouse
- 5.7 cm
- 9.485 cm
- 3.911 cm
- 80 g
- Localisation
- English / Europe
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- Buttons Qty
- 3
- 1200 cpi
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- AA type
- Installed Qty
- 2
- Run Time (Up To)
- 1 year
- System Requirements Details
- Windows XP/Vista/7
- Shipping Width
- 11 cm
- Shipping Depth
- 7 cm
- Shipping Height
- 5.2 cm
- Shipping Weight
- 0.1 kg
- Limited warranty - 2 years
