The HP X27i 2K gaming monitor is key for your everyday gaming demands. Revel in action-packed moments with smooth, crisp visuals supported by a 144Hz refresh rate and AMD FreeSync technology. 2K resolution with IPS panel technology captivates with stunning details.
144Hz refresh rate
Get smooth gaming, sharper objects, and cleaner details with a gaming display that refreshes frames 144 times a second – over twice the refresh rate of standard displays. -
4-millisecond response time with Overdrive
How fast your pixels can react to changing frames is critical for fast-paced gaming, and a 4-millisecond response time ensures gameplay is fluid, crisp, and free of motion blur. -
See and feel the difference of fluid, responsive gameplay. By synchronizing the refresh rate with your GPU, AMD FreeSync makes display stutter, input lag, and screen tears ancient history. -
QHD Display
Get lost in the captivating definition and ultra-sharp details of 3.7 million pixels. The 2560 x 1440 resolution transforms all your content for a remarkable entertainment experience. -
Step up to the best
No matter where you stand, an HP IPS monitor delivers clear, vivid images. IPS technology ensures image accuracy and consistency across the ultra-wide viewing spectrum. Enjoy the same wide viewing experience as premium tablets and mobile devices. -
Height adjustment stand
Gas piston design allows 130mm of smooth, precise height adjustment so your display is always in the most comfortable position, no matter who is viewing it.
- HP X27i Gaming Monitor - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/356888
- Energy Class
- Class G
- Energy Consumption per Year
- 41 kWh
- Power Consumption (On mode)
- 32.1 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 144 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (grey-to-grey)
- Gaming
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100 - 240 V
- 61.12 cm 51.12 cm
- 7.35 kg
- Localisation
- English / United Kingdom
- Plug and Play, NOM, TUV S, CB, PSB, ISO 9241-307, WEEE, ICES, TUV Bauart, KC, BIS, DisplayPort 1.2, TUV LBL, Mexico Energy label, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label
- 1-year warranty
- Display Type
- Energy Class
- Class G
- 41 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- Vertical Refresh Rate
- 144 Hz
- Horizontal Refresh Rate
- 223 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, DreamColor, Flicker Free technology, Technicolour Colour certified, Low Blue Light technology
- 61.12 cm 51.12 cm - with stand
- 7.35 kg
Audio
- Speakers
- DisplayPort , HDMI , Audio line-out , Headphone/microphone combo jack
Mechanical
- Tilt Angle
- -4/+20
- Swivel Angle
- 360
- Rotation Angle
- 180
- Height Adjustment
- 13.14 cm
- VESA Mounting Interface
- 100 mm
- Security lock slot (cable lock sold separately), arsenic free, mercury free
- Included Accessories
- VESA bracket
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100 - 240 V
- 32.1 W
- Power Consumption SDR (On mode)
- 32.1 kWh/1000h
- Power Consumption Stand by
- 0.32 watt
- 0.24 watt
- Dimensions & Weight Details
- With stand - width: 61.12 cm - height: 51.12 cm - weight: 7.35 kg , Without stand - width: 61.12 cm - depth: 5.81 cm - height: 37.96 cm
- Shipping Width
- 70.2 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 46.3 cm
- Shipping Weight
- 9.3 kg
- Limited warranty - parts and labour - 1 year
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
