HP X27I 2K Gaming Monitor
Quicklinx: G770WS00 Mfr#: 8GC08AA#ABU
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort
£307.31 ex VAT
£368.77 inc VAT
The HP X27i 2K gaming monitor is key for your everyday gaming demands. Revel in action-packed moments with smooth, crisp visuals supported by a 144Hz refresh rate and AMD FreeSync technology. 2K resolution with IPS panel technology captivates with stunning details.
  • 144Hz refresh rate
    Get smooth gaming, sharper objects, and cleaner details with a gaming display that refreshes frames 144 times a second – over twice the refresh rate of standard displays.
  • 4-millisecond response time with Overdrive
    How fast your pixels can react to changing frames is critical for fast-paced gaming, and a 4-millisecond response time ensures gameplay is fluid, crisp, and free of motion blur.
  • AMD FreeSync technology
    See and feel the difference of fluid, responsive gameplay. By synchronizing the refresh rate with your GPU, AMD FreeSync makes display stutter, input lag, and screen tears ancient history.
  • QHD Display
    Get lost in the captivating definition and ultra-sharp details of 3.7 million pixels. The 2560 x 1440 resolution transforms all your content for a remarkable entertainment experience.
  • Step up to the best
    No matter where you stand, an HP IPS monitor delivers clear, vivid images. IPS technology ensures image accuracy and consistency across the ultra-wide viewing spectrum. Enjoy the same wide viewing experience as premium tablets and mobile devices.
  • Height adjustment stand
    Gas piston design allows 130mm of smooth, precise height adjustment so your display is always in the most comfortable position, no matter who is viewing it.
HP X27i Gaming Monitor - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
32.1 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Gaming
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100 - 240 V
61.12 cm 51.12 cm
7.35 kg
English / United Kingdom
Plug and Play, NOM, TUV S, CB, PSB, ISO 9241-307, WEEE, ICES, TUV Bauart, KC, BIS, DisplayPort 1.2, TUV LBL, Mexico Energy label, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label
1-year warranty
Display Type
Energy Class
Class G
41 kWh
Diagonal Size
27"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
144 Hz
Horizontal Refresh Rate
223 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, DreamColor, Flicker Free technology, Technicolour Colour certified, Low Blue Light technology
61.12 cm 51.12 cm - with stand
7.35 kg
Audio
Speakers
DisplayPort , HDMI , Audio line-out , Headphone/microphone combo jack
Mechanical
Tilt Angle
-4/+20
Swivel Angle
360
Rotation Angle
180
Height Adjustment
13.14 cm
VESA Mounting Interface
100 mm
Security lock slot (cable lock sold separately), arsenic free, mercury free
VESA bracket
Security Slot Type
Kensington security slot
Input Voltage
AC 100 - 240 V
32.1 W
32.1 kWh/1000h
Power Consumption Stand by
0.32 Watt
Power Consumption (Off Mode)
0.24 Watt
Dimensions & Weight Details
With stand - width: 61.12 cm - height: 51.12 cm - weight: 7.35 kg , Without stand - width: 61.12 cm - depth: 5.81 cm - height: 37.96 cm
Shipping Width
70.2 cm
Shipping Depth
19 cm
Shipping Height
46.3 cm
Shipping Weight
9.3 kg
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
G770 HP Care Pack Pick-Up and Return Service Extended Service Agreement 3 Years In Stock £16.29
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: HP
