HP x2 1012 Protective Case
REDUCED TO CLEAR!
Clearance
Last Few Remaining
Quicklinx: C5PNWS00 Mfr#: T3P15AA
Give your HP Elite x2 1012 an extra layer of protection wherever the day takes you with the stylish, business-class HP Elite x2 102 Protective Case.
  • Assemble in a snap
    Simply insert your tablet into the form-fitting, soft-lined case, which has cutouts for all the tablet's ports and inputs so you can stay connected, plus the kickstand so you can use it on a desk or table.
  • Add a keyboard
    Get additional productivity with the optional HP Travel or Advanced Keyboards, which are fully functional with the tablet in the case.
  • Be comfortable
    Carry the case by hand with integrated, removable hand strap or the included shoulder strap.
  • World-class support
    Rest easy with a one-year limited warranty.
HP Protective Case - notebook shell case
Notebook shell case
Location
Upper
Product Material
Polyurethane, polycarbonate
30.6 cm x 1.46 cm x 21.96 cm
298 g
Notebook Compatibility
12"
Removable shoulder strap, adjustable shoulder strap, camera lens cutout, removable hand strap, port cut-outs, logo cutout
Carrying Strap
Hand strap, shoulder carrying strap
1-year warranty
HP Elite x2 1012 G1
Notebook shell case
Location
Upper
Product Material
30.6 cm
1.46 cm
21.96 cm
298 g
12"
Carrying Strap
Limited warranty: - 1 year
HP Elite x2 1012 G1
