HP Workstation Z8 G4 MT Xeon Silver 4108 32GB 1TB Windows 10 Pro
Quicklinx: DVD3WS00 Mfr#: 2WU47ET#ABU
Top-of-the-line power to fuel those who reimagine our world. When you need a workstation with the capability to run complex simulations, handle advanced Machine Learning algorithms and process huge amounts of data, the HP Z8 doesn't disappoint.
  • Operating Systems
    Support your unique user needs with a choice of Windows 10 Pro 64 or Linux operating systems.
  • Processing
    Achieve the performance you need with the ability to support two next generation Intel Xeon processors for up to 56 total processor cores in one system.
  • NVIDIA Quadro GV100
    Give ML developers high-performance GPU-accelerated algorithm development tools with support for the NVIDIA Deep Learning SDK and many widely used deep learning frameworks.
  • Memory
    Easily handle massive data sets with 24 memory slots supporting up to 3 TB of high-speed memory.
  • Expandability
    Get ultra-flexible configuration with 7 high-performance PCIe Gen3 slots and get additional expandability supporting up to 4 PCIe storage devices with optional slots.
  • Power Supply
    Providing a choice of 1125W, 1450W and 1700W 90% efficient power supplies, the Z8 fires up the maximum levels of processing, memory, graphics, storage and I/O configurability.
HP Workstation Z8 G4 - tower Xeon Silver 4108 1.8 GHz - vPro - 32 GB - HDD 1 TB
Workstation - tower
Platform Technology
Intel vPro Platform
Height (Rack Units)
5U
1 x Intel Xeon Silver 4108 / 1.8 GHz (up to 3 GHz, (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
32 GB (installed) / 768 GB (max) - DDR4 SDRAM - ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
No graphics
Audio Output
Stereo
1GbE
OS Provided
Windows 10 Pro for Workstations Plus 64-bit Edition
21.59 cm x 55.12 cm x 44.45 cm
22.4 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
TCO Certified Desktops 9
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Tower - 5U
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
1.8 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C622
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
24 (Total) / 20 (empty)
Registered, mixing of different types of memory modules is not supported, slots 13 - 24 are available in two-processor configuration only, 6-channel memory architecture, non-uniform memory architecture
Configuration Features
4 x 8 GB
RAM Supported
PC4-21300 - 3 TB Load-Reduced - ECC , PC4-21300 - 768 GB registered - ECC
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Interface (Bus) Type
PCI Express
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1as, IEEE 802.3az, IEEE 1588v2
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 4 (total) / 3 (free) x internal 2.5" / 3.5" shared
Slots
2 (total) / 2 (free) x PCIe 3.0 x4 , 4 (total) / 4 (free) x PCIe 3.0 x16 , 3 (total) / 3 (free) x PCIe 3.0 x8
1 x headphones/microphone (1 in front) , 7 x USB 3.1 Gen 1 , 1 x PS/2 mouse , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x serial , USB 3.1 Gen 1 (one of them is charging) , 4 x USB 3.1 (one of them is charging) , 2 x USB-C 3.1 Gen 2
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, Directive 2006/66/EC, ACPI 5.0, low halogen
HP Smart Buy
Power supply
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro for Workstations Plus 64-bit Edition English
Sustainability Information
TCO Certified
21.59 cm
55.12 cm
44.45 cm
22.4 kg
5 °C
35 °C
10 - 85% (non-condensing)
Warranties (3)
DVD3 HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £33.64
DVD3 HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £68.47
DVD3 HP Care Pack Next Business Day Hardware Support with Disk Retention 5 Years - On-Site In Stock £131.89
Other bundles (2)
DVD3 HPE DisplayPort DVI-D Adapter In Stock £19.88
DVD3 HPE USB to Serial Port Adapter In Stock £13.95
