HP Workstation Z6 G4 MT Xeon 4108 32GB 1TB Windows 10 Pro
Quicklinx: DVCYWS00 Mfr#: 2WU44ET#ABU
No matter what the future holds, you'll have all the performance you need. Ideal for VFX and rendering, this workhorse offers a wide range of processing power and the flexibility to upgrade components over time.
  • Operating Systems
    Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems.
  • Processors
    Achieve the performance you need with the ability to support two next generation Intel Xeon processors for up to 56 total processor cores in one system.
  • Graphics
    Get serious about graphics and reach peak productivity with access to a breadth of NVIDIA and AMD professional graphics from entry to ultra 3D.
  • Storage
    Install the fastest professional grade storage hardware around, unlocking performance for storage-bound applications without sacrificing standard PCIe slots.
  • Deliberate design
    The Z6 workstation's sleek, iconic design doesn't compromise on quiet, reliable performance.
  • Unrivaled BIOS protection
    HP SureStart automatically detects intrusions in real-time, notifies you, and restores the BIOS you use, so you can breathe easier.
HP Workstation Z6 G4 - tower - Xeon Silver 4108 1.8 GHz - vPro - 32 GB - HDD 1 TB
Workstation - tower
Platform Technology
Intel vPro Platform
Height (Rack Units)
4U
1 x Intel Xeon Silver 4108 / 1.8 GHz (, up to 3 GHz, (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB
Cache Per Processor
11 MB
RAM
32 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
No graphics
Audio Output
Stereo
1GbE
OS Provided
Windows 10 Pro for Workstations Plus 64-bit Edition
16.9 cm x 46.5 cm x 44.5 cm
13.1 kg
Manufacturer Selling Program
HP Smart Buy
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Tower - 4U
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
1.8 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C622
Cache Memory
Installed Size
11 MB
Cache Per Processor
11 MB
RAM
Installed Size
32 GB / 384 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
12 (Total) / 10 (empty)
Registered, slots 7 - 12 are available in two-processor configuration only, non-uniform memory architecture
Configuration Features
2 x 16 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Interface (Bus) Type
PCI Express 3.0
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), PXE 2.1 support
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x external 5.25" , 2 (total) / 1 (free) x internal 2.5" / 3.5" shared
Slots
3 (total) / 3 (free) x PCIe 3.0 x4 , 2 (total) / 2 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x8 , 2 (total) / 2 (free) x M.2 Card
1 x headphones/microphone (1 in front) , 10 x USB 3.1 Gen 1 - Type A (4 front, 6 rear) (one of them is charging) , 1 x PS/2 mouse , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-in , 1 x audio line-out , PS/2 keyboard
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 5.0, low halogen
HP Smart Buy
Power supply
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro for Workstations Plus 64-bit Edition English
16.9 cm
46.5 cm
44.5 cm
13.1 kg
5 °C
35 °C
10 - 85% (non-condensing)
Warranties (3)
DVCY HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £33.64
DVCY HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £68.47
DVCY HP Care Pack Next Business Day Hardware Support with Disk Retention 5 Years - On-Site In Stock £131.21
Other bundles (2)
DVCY HPE DisplayPort DVI-D Adapter In Stock £19.77
DVCY HPE USB to Serial Port Adapter In Stock £13.95
