HP Workstation Z4 G4 Xeon W-2123 16GB 256GB W10 Pro
Quicklinx: DCQRWS00 Mfr#: 2WU65EA#ABU
  • Xeon
Perfect for engineering, the Z4 delivers mainstream performance for a wide spectrum of applications. With server-grade processing and a full set of components you get everything you need, nothing more.
  • Operating Systems
    Support your unique user needs with a choice of Windows 10 Pro for Workstations 64 or Linux operating systems.
  • Professional Performance
    Run demanding professional apps with the newest generation Intel Xeon processors available with up to 18 cores for powerful performance and productivity.
  • Intel Core X-Series processors
    Experience disruptive price-performance on multi-threaded applications, or combined workflows such as simulation based design, with Intel Core X-Series processors: the high-performance single-socket processors from Intel .
  • Graphics
    Get serious about graphics and reach peak productivity with access to a breadth of NVIDIA and AMD professional graphics from entry to high-end 3D.
  • Storage
    Install pro-grade storage hardware and elevate your storage-bound apps without sacrificing standard PCIe slots.
  • Functional Design
    The simply stunning design features front and rear handles, so you can easily relocate your system.
HP Workstation Z4 G4 - MT - Xeon W-2123 3.6 GHz - vPro - 16 GB - SSD 256 GB - UK
Workstation - mini tower
Platform Technology
Intel vPro Platform
Height (Rack Units)
4U
1 x Intel Xeon W-2123 / 3.6 GHz (, up to 3.9 GHz, (Quad-Core)
Processor Socket
LGA2066 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
8.25 MB
Cache Per Processor
8.25 MB
RAM
16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-20800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive G2, NVM Express (NVMe), multi-level cell (MLC)
Optical Storage
DVD-Writer
Card Reader
Graphics Controller
No graphics
1GbE
Keyboard
OS Provided
Windows 10 Pro for Workstations 64-bit Edition
Software Included
HP Remote Graphics Software, Sobey Video Editing
16.9 cm x 44.5 cm x 38.6 cm
11.3 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini tower - 4U
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Intel Xeon W-2123
Clock Speed
3.6 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA2066 Socket
Chipset Type
Intel C422
Cache Memory
Installed Size
8.25 MB
Cache Per Processor
8.25 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
8 (Total) / 6 (empty)
Registered
Configuration Features
2 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD-Writer - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), PXE support
Bays
2 (total) / 1 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5"
Slots
2 (total) / 2 (free) x PCIe 3.0 x16 , 2 (total) / 2 (free) x PCIe 3.0 x4 , 1 (total) / 1 (free) x PCIe 3.0 x8 , 2 (total) / 1 (free) x M.2 Card
8 x USB 3.1 Gen 1 , 1 x headphones/microphone , 2 x USB 2.0 , 1 x audio line-in , 1 x audio line-out , 2 x USB-C , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, FIPS 140-2, Common Criteria EAL4+, WEEE 2002/96/EC, ISO 11469, ISO 1043
Power supply
Power Provided
750 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro for Workstations 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
16.9 cm
44.5 cm
38.6 cm
11.3 kg
5 °C
35 °C
10 - 85% (non-condensing)
Warranties (1)
DCQR HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site In Stock £33.36
Monitors (2)
DCQR HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
DCQR HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £150.00
Other bundles (3)
DCQR HPE DisplayPort To VGA Adapter In Stock £13.72
DCQR HPE DisplayPort DVI-D Adapter In Stock £13.23
DCQR HPE DisplayPort to VGA Adapter In Stock £16.40
