HP Workstation Z4 G4 MT Xeon W-2123 16GB 1TB Windows 10 Pro
Quicklinx: DVCXWS00 Mfr#: 2WU64ET#ABU
Processor Type: Xeon
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Xeon
22 in stock
£1,163.44 ex VAT
£1,396.12 inc VAT
Perfect for engineering, visualization and Machine Learning, HP's most popular workstation delivers disruptive performance for a wide spectrum of applications. With a choice of Intel Xeon or Core X processors, and support for dual extreme graphics, you get all you need, nothing more.
  • Feature-rich functionality
    The Z4 is ahead of its time with more standard features than any other single processor HP workstation. With multiple configuration options, you can choose the perfect blend of components that meet your performance requirements.
  • Visualization powerhouse
    Visualize your project anytime with the power to move seamlessly between 3D CAD, rendering and simulation applications. The Z4 can easily handle tasks that require high frequency processing, multiple cores and high-powered GPUs for an optimized design process.
  • HP's most secure workstations
    Advanced security features come standard on every Z4. Rest assured your device, identity and data are safe with security software like HP Client Security Suite Gen3 and HP Sure Start Gen3 featuring a self-healing BIOS.
HP Workstation Z4 G4 - MT - Xeon W-2123 3.6 GHz - 16 GB - 1 TB - UK
Workstation - mini tower
Platform Technology
Intel vPro Technology
Height (Rack Units)
4U
1 x Intel Xeon W-2123 / 3.6 GHz (3.9 GHz) (Quad-Core)
Processor Socket
LGA2066 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
8.25 MB
Cache Per Processor
8.25 MB
RAM
16 GB (installed) / 256 GB (max) DDR4 SDRAM - ECC - PC4-20800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
No graphics
GigE
Keyboard
OS Provided
16.9 cm x 44.5 cm x 38.6 cm
11.3 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
Product Form Factor
Mini tower - 4U
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA2066 Socket
Chipset Type
Intel C422
Cache Memory
Installed Size
8.25 MB
Cache Per Processor
8.25 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
8 (Total) / 6 (empty)
Registered
Configuration Features
2 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), PXE support
Bays
2 (total) / 1 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5"
Slots
2 (total) / 2 (free) x PCIe 3.0 x16 , 2 (total) / 2 (free) x PCIe 3.0 x4 , 1 (total) / 1 (free) x PCIe 3.0 x8 , 2 (total) / 1 (free) x M.2 Card
8 x USB 3.1 Gen 1 , 1 x headphones/microphone , 2 x USB 2.0 , 1 x audio line-in , 1 x audio line-out , 2 x USB-C , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, FIPS 140-2, Common Criteria EAL4+, WEEE 2002/96/EC, ISO 11469, ISO 1043
Power supply
Nominal Voltage
Power Provided
750 Watt
80 PLUS Certification
80 PLUS
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
HP Remote Graphics Software, HP Performance Advisor, Sobey Video Editing
ENERGY STAR Certified
16.9 cm
44.5 cm
38.6 cm
11.3 kg
5 °C
35 °C
10 - 85% (non-condensing)
HP Workstation Z4 G4 MT Xeon W-2123 16GB 1TB Windows 10 Pro Bundle deal on HP Workstation Z4 G4 MT Xeon W-2123 16GB 1TB Windows 10 Pro
£1,262.61
Storage Type: HDD
Processor Model: W-2123
Type: Workstation
Case Style: Mini tower
Display: not included
Optical Storage: DVD-Writer
Brand: HP
Price Range Ex VAT: 1000 - 1500
