HP Workstation Z240 SFF Intel Xeon E3-1245V5 16GB 256GB SSD Windows 7 Professional (64-bit)
Quicklinx: C7YYWS00 Mfr#: J9C03ET#ABU
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
  • Choose the OS for you
    Support your unique user needs with a choice of Windows 10 Pro or Linux operating systems.
  • Better Package. Bigger Punch
    Get more performance, expandability and flexibility than our previous generations.
  • Powerful performance
    Achieve the performance you need with your choice of next generation Intel Xeon processors or Intel Core processors.
  • Ultra-fast storage
    Handle large files, reduce work time and increase performance with the optional HP Z Turbo Drive.
  • Work smarter
    Up to 64 GB DDR4 ECC memory helps provide no compromise capacity, performance, and reliability.
  • Geared up graphics
    Ignite productivity with NVIDIA professional graphics cards in 2D or 3D.
HP Workstation Z240 - SFF Xeon E3-1245V5 3.5 GHz - vPro - 16 GB - SSD 256 GB
Workstation - SFF
Platform Technology
Intel vPro Platform
1 x Intel Xeon E3-1245V5 / 3.5 GHz (up to 3.9 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express 3.0 x4 - PCI Express - HP Z Turbo Drive G2
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics P530 Dynamic Video Memory Technology 5.0
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, PDF Complete Corporate Edition, HP Performance Advisor, HP PC Hardware Diagnostics UEFI, HP Client Security, HP Remote Graphics Software 7.1
33.8 cm x 38.1 cm x 10 cm
5.7 kg
Manufacturer Selling Program
HP Smart Buy
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
SFF
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 8 GB
Hard Drive
SSD - PCI Express
1 x 256 GB
Interface Type
PCI Express 3.0 x4
HP Z Turbo Drive G2
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
High Definition Audio
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x 3.5" , 1 (total) / 1 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, low-profile , 2 (total) / 2 (free) x PCIe 3.0 x1 - half-length, low-profile , 1 (total) / 0 (free) x PCIe 3.0 x16 - half-length, low-profile (x4 mode) , 1 (total) / 1 (free) x M.2 Card (x4 mode) , 1 (total) / 0 (free) x M.2 Card (on PCI Express card)
8 x USB 3.0 (2 front, 6 rear) , 2 x USB 2.0 (2 in front) (one of them is charging data port) , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front) , 3 x DisplayPort , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, ACPI 4.0, low halogen
HP Smart Buy
Power supply
Power Provided
240 Watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence - English
Software
33.8 cm
38.1 cm
10 cm
5.7 kg
5 °C
35 °C
8 - 85% (non-condensing)
