HP Workstation Z2 mini G4 Intel Core i7-8700 16GB 512GB SSD Windows 10 Professional 64-bit
Quicklinx: FBV3WS00 Mfr#: 6TL47ET#ABU
Processor Type: Core i7
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 512GB
Storage Type: SSD
  • Core i7
£1,030.32 ex VAT
£1,236.38 inc VAT
Get high-end performance packed into an insanely small and versatile device. Take on 3D design projects and work in multiple pro apps with ease. And with the flexibility to be placed almost anywhere, it's the obvious choice for the modern workplace.
  • Ramp up your performance
    Speed up 3D responsiveness and cut render times with high-performance Intel processors and graphics. Don't worry about overheating this tiny machine-our industry-leading thermal design keeps everything running cool, quiet and efficient.
  • The perfect fit, anywhere
    Improve your workspace with the stunning, versatile design. Mount under a desk, behind a display or in a rack. Flexible I/O ports for peripheral and connectivity needs let you create the ideal setup-from the office to the shop floor to the data center.
  • Safeguard your data
    Advanced security features come standard on every Z2 Mini. System safeguards like HP Client Security Suite Gen3 and HP Sure Start Gen4 - the industry's first self-healing BIOS - mean your device is locked down tight, so your data and identity are too.
HP Workstation Z2 Mini G4 Performance - mini - Core i7 8700 3.2 GHz - 16 GB - SSD 512 GB - UK
Workstation - mini
Platform Technology
Intel vPro Technology
1 x Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 512 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive G2, NVM Express (NVMe), triple-level cell (TLC)
Optical Storage
No optical drive
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
NVIDIA Quadro P600 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
GigE
Keyboard
OS Provided
Space grey with black chrome accents
21.6 cm x 21.6 cm x 5.8 cm
1.93 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
Product Form Factor
Mini
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel C246
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
16 GB / 64 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2 2280
1 x 512 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video Interfaces
DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), ACPI support, PXE support, Intel Active Management Technology (AMT) 12
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode)
4 x USB 3.0 (2 front, 2 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 3 x DisplayPort , 2 x USB-C 3.1 Gen 2 (one of them is charging)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
VESA Mounting Interface
RoHS, WEEE 2002/96/EC
Power adapter
Nominal Voltage
Power Provided
230 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
21.6 cm
21.6 cm
5.8 cm
1.93 kg
5 °C
35 °C
10 - 85% (non-condensing)
HP Workstation Z2 mini G4 Intel Core i7-8700 16GB 512GB SSD Windows 10 Professional 64-bit Bundle deal on HP Workstation Z2 mini G4 Intel Core i7-8700 16GB 512GB SSD Windows 10 Professional 64-bit
£1,129.49
Storage Type: SSD
Processor Model: I7-8700
Type: Workstation
Case Style: Ultra small form factor
Optical Storage: None
Brand: HP
Price Range Ex VAT: 1000 - 1500
