Get high-end performance packed into an insanely small and versatile device. Take on 3D design projects and work in multiple pro apps with ease. And with the flexibility to be placed almost anywhere, it's the obvious choice for the modern workplace.
Windows 10 Pro 64
Work without compromising on performance or security with Windows 10 Pro, powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
NVIDIA Quadro P600 graphics card
Get stable, reliable performance on professional workflows that require you to create complex 2D and 3D models with NVIDIA Quadro P600 graphics.
- HP Workstation Z2 Mini G4 Performance - mini - Core i7 8700 3.2 GHz - vPro - 16 GB - SSD 512 GB - UK
- Workstation - mini
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Core i7 (8th Gen) 8700 / 3.2 GHz (, up to 4.6 GHz, (6-core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 16 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive G2, NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- No optical drive
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Controller
- NVIDIA Quadro P600 / Intel UHD Graphics 630
- Video Memory
- 4 GB GDDR5 SDRAM
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Space grey with black chrome accents
- 21.6 cm x 21.6 cm x 5.8 cm
- 1.93 kg
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Product Form Factor
- Mini
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8700
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel C246
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- 16 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 512 GB
- Interface Type
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Video Interfaces
- DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), ACPI support, PXE support, Intel Active Management Technology (AMT) 12
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode)
- 4 x USB 3.0 (2 front, 2 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 3 x DisplayPort , 2 x USB-C 3.1 Gen 2 (one of them is charging)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- RoHS, WEEE 2002/96/EC
- Power adapter
- Voltage Required
- Power Provided
- 230 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- 21.6 cm
- 21.6 cm
- 5.8 cm
- 1.93 kg
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
Warranties (1)
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site | In Stock | £33.73 |
Monitors (2)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
Accessories (1)
HP VESA Mount Solution - Mounting kit (wall arm) | In Stock | £64.94 |
Other bundles (2)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort to VGA Adapter | In Stock | £16.34 |
