HP Workstation Z2 G9 Tower Intel Core i7-13700 32GB 1TB SSD Windows 11 Professional
Quicklinx: HSCKWS00 Mfr#: 98T49ET#ABU
  • Core i7
Experience a whole new level of performance for your professional workflow. The Z2 Tower is engineered to seamlessly run multi-threaded apps for fast rendering, simulation, and now real-time ray tracing. And when your demands change, you have impressive expandability to upgrade.
  • Windows 11
    Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
  • Security is your top priority
    The HP Wolf Pro Security Edition provides preconfigured enterprise-level PC protection for small and medium sized businesses.
  • Smaller, Functional Design
    The stunning new design features front and rear ledges, so you can easily move your system from location to location.
  • Tool-less Access
    Evolve your work. Evolve your rig. With a tool-less sliding access cover, you can easily get into the the interior, and customize your Z to fit your needs.
  • Thermal Management
    Innovatively designed to keep hardware components cool and quiet no matter how hard you push it. Have confidence to run your system at max load 24/7.
HP Workstation Z2 G9 - tower - AI Workstation - Core i7 13700 2.1 GHz - 32 GB - SSD 1 TB - UK - with HP Wolf Pro Security Edition (1 year)
Workstation - tower - AI Workstation
Height (Rack Units)
4U
1 x Intel Core i7 (13th Gen) 13700 / 2.1 GHz (up to 5.2 GHz, (16-core)
Processor Socket
LGA1700 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache, Intel Turbo Boost Max 3.0
Cache Memory
30 MB L3 Cache
Cache Per Processor
30 MB
RAM
32 GB (installed) / 128 GB (max) - DDR5 SDRAM - non-ECC
Storage Controller
SATA/NVMe (SATA 6Gb/s / PCIe 4.0 x4 (NVMe))
Hard Drive
SSD 1 TB - PCI Express 4.0 x4 - M.2 2280 - HP Z Turbo Drive, NVM Express (NVMe), triple-level cell (TLC)
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel UHD Graphics 770 Unified Memory Architecture (UMA)
1GbE
Keyboard
OS Provided
Windows 11 Pro
Software Included
HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Driver Packs, HP Image Assistant, HP PC Hardware Diagnostics, HP ZCentral Remote Boost, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 4, HP Performance Advisor 3.0
16.9 cm x 38.5 cm x 35.6 cm
7.2 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Bundled with
Workstation
AI Level
AI Workstation
Product Form Factor
Tower - 4U
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Bundled with
Processor / Chipset
CPU
Clock Speed
2.1 GHz (P-core) / 1.5 GHz (E-core)
Max Turbo Speed
5.2 GHz (P-core) / 4.1 GHz (E-core)
Number of Cores
16-core
CPU Qty
1
Max CPU Qty
1
L2 cache
24 MB
CPU Upgradability
Upgradable
CPU Socket
LGA1700 Socket
Chipset Type
Intel W680
Cache Memory
Installed Size
L3 Cache - 30 MB
Cache Per Processor
30 MB
RAM
Installed Size
Effective Memory Speed
4800 MHz
Rated Memory Speed
4800 MHz
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 16 GB
Hard Drive
SSD - M.2 2280
1 x 1 TB
Interface Type
PCI Express 4.0 x4
Storage Controller
1 x SATA/NVMe
Controller Interface Type
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
USB
Localization & Layout
Mouse
Mouse Name
HP 320M
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, Intel Active Management Technology (AMT) 16
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external 5.25" , 1 (total) / 1 (free) x external 5.25" Slim Line , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x PCIe 5.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height (x1 mode, open ended) , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height (open ended) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 3 (total) / 2 (free) x M.2 Card - 2280 , 1 (total) / 1 (free) x M.2 Card - 2230 (PCIe 3.0 x1 mode and Intel CNVi wireless module)
1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 6 x USB 3.2 Gen 2 (4 front, 2 rear) (one of them is charging) , 1 x audio line-in , 1 x audio line-out , 2 x DisplayPort 1.4 , 3 x USB 2.0 , 1 x USB 3.2 Gen 1 , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, FIPS 140-2, WEEE, Energy-Related Products (ErP) Lot 6, CECP, SEPA, low halogen
HP Smart Buy
Power supply
Power Provided
700 watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 11 Pro English
Software
Sustainability Information
ENERGY STAR Certified
16.9 cm
38.5 cm
35.6 cm
7.2 kg
Shipping Width
29.5 cm
Shipping Depth
49 cm
Shipping Height
51.8 cm
5 °C
35 °C
10 - 85% RH (non-condensing)
Warranties (2)
HSCK HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site In Stock £46.86
HSCK HP Electronic Care Pack Next Business Day Hardware In Stock £33.64
Monitors (7)
HSCK HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £166.22
HSCK HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £501.52
HSCK HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £615.80
HSCK HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £167.33
HSCK HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor In Stock £76.56
HSCK HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor In Stock £112.58
HSCK HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor In Stock £251.00
Keyboards and Mice (4)
HSCK HP 128 Wired Mouse In Stock £8.49
HSCK HP 455 Programmable Keyboard - Wireless - UK In Stock £46.54
HSCK HP Desktop 320MK - Keyboard and mouse set - full size - USB - UK - black In Stock £15.40
HSCK HP 320K Wired Keyboard In Stock £11.79
Other bundles (31)
HSCK HPE DisplayPort DVI-D Adapter In Stock £19.77
HSCK HPE DisplayPort to VGA Adapter In Stock £13.14
HSCK Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter In Stock £208.06
HSCK Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A In Stock £216.07
HSCK Poly Voyager 4320 UC V4320-M C USB-A WW In Stock £103.25
HSCK Poly Voyager 4320 UC V4320 C USB-C WW In Stock £106.60
HSCK Poly TRIO C60 EXPANSION MICROPHONES In Stock £147.98
HSCK Poly Voyager 4320 UC V4320-M C USB-C WW In Stock £103.25
HSCK Poly Voyager 4320 UC V4320 C USB-C CS WW In Stock £117.00
HSCK Poly Voyager 4320 UC V4320-M C USB-C CS WW In Stock £111.68
HSCK Poly Voyager 4320 UC V4320 C USB-A WW In Stock £103.25
HSCK Poly Voyager 4310 UC V4310 C USB-A WW In Stock £98.17
HSCK Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C In Stock £109.67
HSCK Poly Poly Blackwire 3320 Stereo USB-C/A Adapter In Stock £29.68
HSCK Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C In Stock £68.27
HSCK Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified In Stock £45.04
HSCK HyperX SoloCast USB Microphone In Stock £50.55
HSCK Poly Blackwire 3210 headset - on-ear - wired - USB-C - black In Stock £25.87
HSCK Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter In Stock £59.09
HSCK Poly Blackwire 3310 headset - on-ear - wired - USB-A - black In Stock £24.80
HSCK Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £29.67
HSCK Poly Blackwire 3220 headset - on-ear - wired - USB-C - black In Stock £25.27
HSCK Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter In Stock £24.80
HSCK Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams In Stock £108.17
HSCK Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £49.75
HSCK Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C In Stock £48.40
HSCK Poly HP Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C In Stock £46.27
HSCK Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C In Stock £53.80
HSCK Poly Blackwire 3220 USB-C HS +USB-C/A Headset In Stock £26.96
HSCK Poly Blackwire 5220 USB-C HS +USB-C/A Headset In Stock £55.67
