Tackle workflows you never thought before possible on such a tiny PC. The HP Z2 Mini easily fits on your desk or behind your monitor so you can tackle 3D projects without losing valuable office space. All while feeling protected From the BIOS to the browser, above, in, and below the OS with HP Wolf Security Suite.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
Multi-Display Support
See all your windows in perfect detail with support for up to 8 displays at 4K resolution. -
Tool-less Access
Evolve your work. Evolve your rig. With a tool-less sliding access cover, you can easily get into the the interior, and customize your Z to fit your needs. -
Network Connectivity
Connect and collaborate quickly with 10Gb Ethernet interface. -
Thermal Management
Innovatively designed to keep hardware components cool and quiet no matter how hard you push it. Have confidence to run your system at max load 24/7.
- HP Workstation Z2 G9 - mini - AI Workstation - Core i7 13700K 3.4 GHz - 32 GB - SSD 1 TB - UK
- Workstation - mini - AI Workstation
- Height (Rack Units)
- 5U
- Localisation
- Processor
- 1 x Intel Core i7 (13th Gen) 13700K / 3.4 GHz (up to 5.4 GHz, (16-core)
- Processor Socket
- LGA1700 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache, Intel Turbo Boost Max 3.0
- Cache Memory
- 30 MB L3 Cache
- Cache Per Processor
- 30 MB
- RAM
- 32 GB (installed) / 64 GB (max) - DDR5 SDRAM - non-ECC
- Storage Controller
- SATA/NVMe (SATA 6Gb/s / PCIe 4.0 x4 (NVMe))
- Hard Drive
- SSD 1 TB - PCI Express 4.0 x4 - M.2 2280 - HP Z Turbo Drive, NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- No optical drive
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Controller
- PCIe 4.0 x16 - NVIDIA RTX A2000 / Intel UHD Graphics 770
- Video Memory
- 12 GB GDDR6 SDRAM
- Networking
- 1GbE
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- Windows 11 Pro
- Software Included
- HP Support Assistant, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Image Assistant, HP PC Hardware Diagnostics, HP Sure Click, HP Manageability Integration Kit, HP Sure Admin, HP Client Security Manager Gen6, HP BIOSphere Gen6, HP ZCentral Remote Boost, HP Sure Recover Gen4, HP Performance Advisor 3.0, HP Sure Sense Gen2, HP Sure Run Gen5, HP Sure Start Gen7
- 21.1 cm x 21.8 cm x 6.9 cm
- 2.4 kg
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- AI Level
- AI Workstation
- Product Form Factor
- Mini - 5U
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Core i7 (13th Gen) 13700K
- Clock Speed
- 3.4 GHz (P-core) / 2.5 GHz (E-core)
- Max Turbo Speed
- 5.4 GHz (P-core) / 4.2 GHz (E-core)
- Number of Cores
- 16-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- L2 cache
- 24 MB
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1700 Socket
- Chipset Type
- Intel W680
Cache Memory
- Installed Size
- L3 Cache - 30 MB
- 30 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 5600 MHz
- Rated Memory Speed
- 5600 MHz
- Form Factor
- SO-DIMM 262-pin
- Slots
- 2 (Total) / 0 (empty)
- Dual channel memory architecture
- Configuration Features
- 2 x 16 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 1 TB
- Interface Type
Storage Controller
- 1 x SATA/NVMe
- Controller Interface Type
- SATA 6Gb/s / PCIe 4.0 x4 (NVMe)
- RAID Level
- RAID 0, RAID 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Interface Type
- PCIe 4.0 x16
- Graphics Processor
- Video Memory
- 12 GB GDDR6 SDRAM
- Bandwidth
- 288 GBps
- Video Interfaces
- DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP 320K
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP 320M
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), auto-uplink (auto MDI/MDI-X), PXE 2.1 support, Intel Active Management Technology (AMT) 16
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.3az
- Slots
- 1 (total) / 0 (free) x PCIe 4.0 x16 , 2 (total) / 1 (free) x M.2 Card - 2280 (PCIe 4.0 x4 mode) , 1 (total) / 1 (free) x M.2 Card (for Intel CNVi wireless module)
- 1 x headphones/microphone (CTIA and OMTP headset support) , 4 x USB 3.2 Gen 2 (charging) , 2 x USB-C 3.2 Gen 2x2 (charging) , 2 x DisplayPort 1.4 , 1 x LAN (Gigabit Ethernet) , 4 x Mini DisplayPort 1.4
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, FIPS 140-2, WEEE, CECP, low halogen
- HP Smart Buy
- Power adapter
- Voltage Required
- AC 115/230 V (50/60 Hz)
- Power Provided
- 280 watt
- Efficiency
- 89%
- Power Factor Correction
Operating System / Software
- OS Provided
- Windows 11 Pro English
- Software
Sustainability Information
- ENERGY STAR Certified
- 21.1 cm
- 21.8 cm
- 6.9 cm
- 2.4 kg
- Shipping Width
- 17 cm
- Shipping Depth
- 49.9 cm
- Shipping Height
- 29.8 cm
- Shipping Weight
- 4.8 kg
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
Warranties (2)
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site | In Stock | £45.90 |
HP Electronic Care Pack Next Business Day Hardware | In Stock | £32.96 |
Monitors (5)
HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £164.32 |
HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £491.31 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £165.42 |
HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor | In Stock | £77.18 |
HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £115.80 |
Keyboards and Mice (5)
HP 128 Wired Mouse | In Stock | £8.48 |
HP 455 Programmable Keyboard - Wireless - UK | In Stock | £26.44 |
HP 125 - Mouse - wired - USB - black | In Stock | £6.20 |
HP Desktop 320MK - Keyboard and mouse set - full size - USB - UK - black | In Stock | £15.39 |
HP 320K Wired Keyboard | In Stock | £11.78 |
Other bundles (29)
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £208.06 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £208.06 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £108.17 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £106.60 |
Poly DA85-M Sound Card | In Stock | £44.59 |
Poly TRIO C60 EXPANSION MICROPHONES | In Stock | £144.27 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £65.27 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £43.62 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £108.44 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £98.17 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £115.93 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £106.60 |
Poly Voyager 4310 UC V4310 C USB-A WW | In Stock | £98.17 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £87.21 |
Poly Voyager Focus 2 UC-M USB-C Headset with Stand | In Stock | £141.12 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £109.27 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £32.44 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £35.37 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £67.04 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £45.04 |
Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager | In Stock | £89.69 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £61.00 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.93 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £24.80 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £77.77 |
Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams | In Stock | £108.17 |
Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £48.40 |
Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £48.57 |
