Experience a whole new level of performance for your professional workflow. The Z2 Tower is engineered to seamlessly run multi-threaded apps for fast rendering, simulation, and now real-time ray tracing. And when your demands change, you have impressive expandability to upgrade.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
Smaller, Functional Design
The stunning new design features front and rear ledges, so you can easily move your system from location to location. -
Tool-less Access
Evolve your work. Evolve your rig. With a tool-less sliding access cover, you can easily get into the the interior, and customize your Z to fit your needs. -
Thermal Management
Innovatively designed to keep hardware components cool and quiet no matter how hard you push it. Have confidence to run your system at max load 24/7. -
Unthrottled Performance
Z's industry-leading thermals keep the processor and graphics card cool, so they can run at max performance for extended periods of time.
- HP Workstation Z2 G9 - tower - AI Workstation - Core i7 12700 2.1 GHz - vPro - 32 GB - SSD 1 TB - UK
- Workstation - tower - AI Workstation
- Platform Technology
- Intel vPro Platform
- Height (Rack Units)
- 4U
- Localisation
- Processor
- 1 x Intel Core i7 (12th Gen) 12700 / 2.1 GHz (up to 4.9 GHz, (12-core)
- Processor Socket
- LGA1700 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache, Intel Turbo Boost Max 3.0
- Cache Memory
- 25 MB L3 Cache
- Cache Per Processor
- 25 MB
- RAM
- 32 GB (installed) / 128 GB (max) - DDR5 SDRAM - non-ECC
- Storage Controller
- SATA/NVMe (SATA 6Gb/s / PCIe 4.0 x4 (NVMe))
- Hard Drive
- SSD 1 TB - PCI Express 4.0 x4 - M.2 2280 - HP Z Turbo Drive, NVM Express (NVMe), triple-level cell (TLC)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 770
- Networking
- 1GbE
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- Windows 10 Pro for Workstations 64-bit Edition (downgrade from Windows 11 Pro for Workstations) + Windows 11 Pro for Workstations Licence
- Software Included
- HP Support Assistant, HP Performance Advisor, Windows Defender, HP PC Hardware Diagnostics UEFI, HP Secure Erase, HP Image Assistant, HP Documentation, HP PC Hardware Diagnostics, HP System Software Manager, HP Notifications, Power On Authentication, HP Privacy Settings, HP Cloud Recovery, HP QuickDrop, HP BIOSphere Gen6, HP Desktop Support Utility, myHP, Touchpoint Customiser for Commercial, HP Easy Clean, HP Client Security Suite Gen7, HP UWP Pack
- Black
- 16.9 cm x 38.5 cm x 35.6 cm
- 7.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- AI Level
- AI Workstation
- Product Form Factor
- Tower - 4U
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Intel Core i7 (12th Gen) 12700
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 4.9 GHz
- Number of Cores
- 12-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1700 Socket
- Chipset Type
- Intel W680
Cache Memory
- Installed Size
- L3 Cache - 25 MB
- 25 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 4800 MHz
- Rated Memory Speed
- 4800 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 32 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 1 TB
- Interface Type
Storage Controller
- 1 x SATA/NVMe
- Controller Interface Type
- SATA 6Gb/s / PCIe 4.0 x4 (NVMe)
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP 320K
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP 320M
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, Intel Active Management Technology (AMT) 16
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x external 5.25" ¦ 1 (total) / 1 (free) x external 5.25" Slim Line ¦ 2 (total) / 2 (free) x internal 3.5" ¦ 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 1 (free) x PCIe 5.0 x16 , 1 (total) / 1 (free) x PCIe 3.0 x4 (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x4 , 3 (total) / 2 (free) x M.2 Card - 2280 (PCIe 4.0 x4 mode) , 1 (total) / 1 (free) x M.2 Card - 2230 (PCIe 3.0 x1 mode and Intel CNVi wireless module)
- 1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 6 x USB 3.2 Gen 2 (4 front, 2 rear) (one of them is charging) , 1 x audio line-in , 1 x audio line-out , 2 x DisplayPort 1.4 , 3 x USB 2.0 , 1 x USB 3.2 Gen 1 , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- RoHS, FIPS 140-2, WEEE, Energy-Related Products (ErP) Lot 6, CECP, SEPA, low halogen
- Power supply
- Voltage Required
- AC 90-269 V (50/60 Hz)
- Power Provided
- 700 Watt
- Efficiency
- 92%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro for Workstations 64-bit Edition (available through downgrade rights from Windows 11 Pro for Workstations) + Windows 11 Pro for Workstations Licence - English
- Software
Sustainability Information
- ENERGY STAR Certified
- 16.9 cm
- 38.5 cm
- 35.6 cm
- 7.2 kg
- Shipping Width
- 29.5 cm
- Shipping Depth
- 49 cm
- Shipping Height
- 51.8 cm
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
Warranties (2)
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site | In Stock | £45.90 |
HP Electronic Care Pack Next Business Day Hardware | In Stock | £32.96 |
Monitors (3)
HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £164.32 |
HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £491.31 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £165.42 |
Keyboards and Mice (2)
HP 128 Wired Mouse | In Stock | £8.48 |
HP 455 Programmable Keyboard - Wireless - UK | In Stock | £26.28 |
Other bundles (28)
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £208.06 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £208.06 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £108.17 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £106.60 |
Poly TRIO C60 EXPANSION MICROPHONES | In Stock | £144.27 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £110.85 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £98.17 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £115.93 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £106.60 |
Poly Voyager 4310 UC V4310 C USB-A WW | In Stock | £98.17 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £109.27 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £32.44 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £35.37 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £67.04 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £45.04 |
Poly Blackwire 3210 headset - on-ear - wired - USB-C - black | In Stock | £25.87 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £61.00 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.93 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.27 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £24.80 |
Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams | In Stock | £108.17 |
Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £48.40 |
Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £48.57 |
Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C | In Stock | £40.91 |
Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C | In Stock | £61.00 |
Poly Blackwire 3220 USB-C HS +USB-C/A Headset | In Stock | £26.96 |
Poly Blackwire 5220 USB-C HS +USB-C/A Headset | In Stock | £63.33 |
