Get high-end performance in a compact device. Completely redesigned to pack more graphics and processing into less space, you can easily take on complex 3D design projects. And with near endless configuration options, it's the ideal hardware when you need a custom solution.
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
NVIDIA Quadro P620 graphics card
Get stable, reliable performance on professional workflows that require you to create complex 2D and 3D models with NVIDIA Quadro P620 graphics. -
Smaller, Functional Design
The stunning new design features front and rear ledges, so you can easily move your system from location to location.
- HP Workstation Z2 G5 - SFF Core i7 10700 2.9 GHz - vPro - 16 GB - SSD 512 GB - UK
- Workstation - SFF
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- 1 x Intel Core i7 (10th Gen) 10700 / 2.9 GHz (up to 4.8 GHz, (8-core)
- Processor Socket
- FCLGA1200 Socket
- Processor Main Features
- Intel Turbo Boost Technology
- Cache Memory
- 16 MB L3 Cache
- Cache Per Processor
- 16 MB
- RAM
- 16 GB (installed) / 128 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive, triple-level cell (TLC)
- Optical Storage
- No optical drive
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Controller
- PCIe 3.0 x16 - NVIDIA T600 / Intel UHD Graphics 630
- Video Memory
- 4 GB GDDR6 SDRAM
- Networking
- 1GbE
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition (downgrade from Windows 11 Pro) + Windows 11 Pro Licence
- Software Included
- HP ZCentral Remote Boost 2020
- Black
- 33.8 cm x 30.8 cm x 10 cm
- 5.4 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - parts and labour - 3 years - on-site
- Workstation
- Product Form Factor
- SFF
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Intel Core i7 (10th Gen) 10700
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 4.8 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA1200 Socket
- Chipset Type
- Intel W480
Cache Memory
- Installed Size
- L3 Cache - 16 MB
- 16 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2933 MHz
- Rated Memory Speed
- 3200 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 2 (empty)
- Configuration Features
- 2 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 512 GB
- Interface Type
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Interface Type
- PCIe 3.0 x16
- Graphics Processor
- Video Memory
- 4 GB GDDR6 SDRAM
- Video Interfaces
- DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X), PXE 2.1 support, Intel Active Management Technology (AMT) 12
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x internal 2.5" , 1 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 1 (free) x internal 3.5"
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 (PCIe 3.0 x1 mode and Intel CNVi wireless module) , 2 (total) / 1 (free) x M.2 Card - 2280 (x4 mode) , 1 (total) / 0 (free) x PCIe 3.0 x16 - half-length, low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, low-profile (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 - half-length, low-profile (open ended) , 1 (total) / 1 (free) x Flex I/O
- 2 x USB 3.2 Gen 1 (2 in front) (one of them is charging) , 1 x headphones/microphone (1 in front) (CTIA and OMTP headset support) , 1 x LAN (Gigabit Ethernet) , 2 x DisplayPort 1.4 , 4 x USB 3.2 Gen 2 - Type A (2 front, 2 rear) , 2 x USB 2.0 , 1 x audio line-out , 1 x USB-C 3.2 Gen 2 (1 in front) (charging) , 2 x USB 3.2 Gen 1 - Type A , 4 x Mini DisplayPort
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, CCC, RoHS, WEEE, Common Criteria EAL4+, CECP
- Power supply
- Voltage Required
- AC 90-269 V (50/60 Hz)
- Power Provided
- 450 watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 33.8 cm
- 30.8 cm
- 10 cm
- 5.4 kg
- Shipping Width
- 22.8 cm
- Shipping Depth
- 39.9 cm
- Shipping Height
- 49.9 cm
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
Warranties (1)
HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site | In Stock | £46.86 |
Other bundles (2)
HPE DisplayPort DVI-D Adapter | In Stock | £19.88 |
HPE DisplayPort to VGA Adapter | In Stock | £13.22 |
