HP Workstation Z2 G5 Mini Intel Core i7-10700 16GB 512GB SSD Windows 10 Professional 64-bit
Quicklinx: GYJ1WS00 Mfr#: 12M16EA#ABU
  • Core i7
Get even more high-end performance packed into an insanely small device. Take on 3D design projects and work in multiple pro apps easily. Widely versatile, it's the obvious choice for the modern workplace.
  • Windows 10 Pro for Workstations 64
    Work without compromising on performance or security with Windows 10 Pro for Workstations, powered by HP's collaboration and connectivity technology.
  • Intel Core i7 processor
    Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor.
  • NVIDIA Quadro P620 graphics card
    Get stable, reliable performance on professional workflows that require you to create complex 2D and 3D models with NVIDIA Quadro P620 graphics.
HP Workstation Z2 Mini G5 - mini Core i7 10700 2.9 GHz - vPro - 16 GB - SSD 512 GB - UK
Workstation - mini
Platform Technology
Intel vPro Platform
1 x Intel Core i7 (10th Gen) 10700 / 2.9 GHz (up to 4.8 GHz, (8-core)
Processor Socket
FCLGA1200 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
16 MB
Cache Per Processor
16 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-25600
Storage Controller
SATA
Hard Drive
SSD 512 GB - PCI Express 3.0 x4 - M.2 2280 - HP Z Turbo Drive, triple-level cell (TLC)
Optical Storage
No optical drive
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
PCIe 3.0 x16 - NVIDIA Quadro P620 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
1GbE
Keyboard
(50/60 Hz)
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP ZCentral Remote Boost 2020
21.6 cm x 21.6 cm x 5.8 cm
2.1 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mini
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.9 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
FCLGA1200 Socket
Chipset Type
Intel W480
Cache Memory
Installed Size
16 MB
Cache Per Processor
16 MB
RAM
Installed Size
Effective Memory Speed
3200 MHz
Rated Memory Speed
3200 MHz
Memory Specification Compliance
PC4-25600
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Dual channel memory architecture
Configuration Features
2 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 512 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
RAID Level
RAID 0, RAID 1
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe 3.0 x16
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video Interfaces
DisplayPort
Max Monitors Supported
3
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP 320K
USB
Localization & Layout
Mouse
Mouse Name
HP 320M
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Slots
1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 2 (total) / 1 (free) x M.2 Card - 2280 (x4 mode) , 1 (total) / 0 (free) x MXM (x16 mode)
4 x USB 3.1 Gen 2 (2 rear, 2 side) (one of them is charging) , 1 x headphones/microphone (1 side) , 1 x LAN (Gigabit Ethernet) , 3 x DisplayPort , 1 x USB-C 3.1 Gen 2 (1 side) (charging)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, Common Criteria EAL4+, CECP
Power adapter
AC 90-264 V (50/60 Hz)
Power Provided
280 watt
Efficiency
89%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
21.6 cm
21.6 cm
5.8 cm
2.1 kg
Shipping Width
17 cm
Shipping Depth
49.9 cm
Shipping Height
29.8 cm
5 °C
35 °C
10 - 85% (non-condensing)
Warranties (2)
GYJ1 HP Care Pack Next Business Day Hardware Support with Defective Media Retention - 3 years - on-site In Stock £46.86
GYJ1 HP Electronic Care Pack Next Business Day Hardware In Stock £33.64
Accessories (1)
GYJ1 HP VESA Mount Solution - Mounting kit (wall arm) In Stock £65.53
Monitors (2)
GYJ1 HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor In Stock £501.52
GYJ1 HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor In Stock £167.33
Other bundles (2)
GYJ1 HPE DisplayPort DVI-D Adapter In Stock £19.77
GYJ1 HPE DisplayPort to VGA Adapter In Stock £13.14
