HP Workstation Z2 G4 SFF Intel Core i7-8700 16GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: FBV5WS00 Mfr#: 4RW90ET#ABU
Processor Type: Core i7
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Core i7
Hurry, only 2 left in stock!
£771.11 ex VAT
£925.33 inc VAT
Get high-end performance in a compact device. Take on 3D design projects and work in multiple pro apps with ease. And with near endless configuration options, it's the ideal hardware if you need a custom solution.
  • Take processing to record speeds
    Crush demanding single and multi-threaded workflows and take on aggressive multi-tasking without throttling. We redesigned our proprietary motherboard to give you full performance, while keeping components running cool and quiet.
  • Forget off the shelf
    Build a system matched exactly to your needs with over a million possible configurations. Keep clear of messy dongles and adapters-with customizable I/O ports you can support new, legacy and specialized equipment.
  • Safeguard your data
    Advanced security features come standard on every Z2 Small Form Factor. System safeguards like HP Client Security Suite Gen3 and HP Sure Start Gen4 - the industry's first self-healing BIOS - mean your device is locked down tight, so your data and identity are too.
HP Workstation Z2 G4 - SFF - Core i7 8700 3.2 GHz - 16 GB - 256 GB - UK
Workstation - small form factor
Platform Technology
Intel vPro Technology
1 x Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
16 GB (installed) / 64 GB (max) DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB - PCI Express 3.0 x4 - M.2 - HP Z Turbo Drive
Optical Storage
DVD-Writer
Graphics Controller
Intel UHD Graphics 630 Dynamic Video Memory Technology 5.0
GigE
Keyboard
OS Provided
33.8 cm x 38.1 cm x 10 cm
5.5 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Workstation
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C246
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
16 GB / 64 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered
Configuration Features
2 x 8 GB
RAM Supported
64 GB unbuffered - ECC , 64 GB unbuffered - non-ECC
Hard Drive
SSD - M.2
1 x 256 GB
Interface Type
PCI Express 3.0 x4
HP Z Turbo Drive
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), ACPI support, PXE support, Intel Active Management Technology (AMT) 12
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x4 - low-profile (x1 mode) , 2 (total) / 1 (free) x M.2 Card - low-profile (x4 mode) , 1 (total) / 1 (free) x M.2 Card - low-profile (x1 mode)
6 x USB 3.0 (2 front, 4 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 2 x DisplayPort , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, WEEE
Power Provided
310 Watt
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
33.8 cm
38.1 cm
10 cm
5.5 kg
Shipping Width
22.9 cm
Shipping Depth
51.8 cm
Shipping Height
49.9 cm
Shipping Weight
9.35 kg
5 °C
35 °C
10 - 85% (non-condensing)
HP Workstation Z2 G4 SFF Intel Core i7-8700 16GB 256GB SSD Windows 10 Professional 64-bit Bundle deal on HP Workstation Z2 G4 SFF Intel Core i7-8700 16GB 256GB SSD Windows 10 Professional 64-bit
£870.28
Storage Type: SSD
Processor Model: I7-8700
Type: Workstation
Case Style: Desktop
Optical Storage: DVD-Writer
Brand: HP
Price Range Ex VAT: 750 - 1000
