HP Wireless Speaker S6500 Black
Quicklinx: C6K6WS00 Mfr#: N5G09AA#ABB
Turn up the value. The HP S6500 is a portable speaker that combines great audio with impressive features. Stream your favorite sounds for up to 10 hours, and enjoy high-quality audio anywhere.
  • Stylish sound
    Spread the sound around with a crisp top-firing audio driver. With soft-touch paint in black or white, this beauty looks as good as it sounds.
  • Packed with features
    Connect with a 10 m (30 ft) Bluetooth range or plug in your favorite device. Built-on buttons keep you in control, and the long-lasting battery keeps you moving for up to 10 hours.
  • Backed by HP
    Your device comes fully supported by HP. Get a 2 years limited warranty included.
HP S6500 - speaker - for portable use - wireless
Speaker - for portable use
English / Europe
Speaker Type
Active
Continuous Power
2 Watt
Peak Power
2.8 Watt
Frequency Response
200 - 12000 Hz
Amplifier
Integrated
Bluetooth
Soft touch black
Power Options
USB charging
Speaker battery rechargeable
7.74 cm x 8.32 cm x 8.02 cm
270 g
Enclosure Colour
Soft touch black
English / Europe
Speaker System
Speaker Type
Active
Continuous Power
2 Watt
Peak Power
2.8 Watt
Frequency Response
200 - 12000 Hz
Amplifier
Integrated
Bluetooth
Transmission Range
10 m
Controls
Power on/off, volume, play/pause
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
USB cable
Power Source
Options
USB charging
Rechargeable
Run Time (Up To)
10 hour(s)
7.74 cm
8.32 cm
8.02 cm
270 g
Shipping Width
13 cm
Shipping Depth
10.8 cm
Shipping Height
9.8 cm
Shipping Weight
0.4 kg
