Maximize your available workspace and conserve your USB ports with the compact, full-featured HP Wireless (Link-5) Keyboard, designed to complement the 2015 class of HP Business PCs.
Bold redesign
Pair your PC with a sleek, restyled, reduced-size keyboard that packs a familiar notebook-style layout and function keys into a smaller design to give you more room on the desk. The comfortably intuitive, low-profile, quiet keys make data entry easy. -
Connect wirelessly
Feel free to move around the desk or table with a keyboard that works up to 30 ft (10 m) away from your PC through the USB nano-receiver, which uses HP Link-5 technology to pair with and connect to up to five HP Link-5 compatible devices. -
Powerful battery
Work without worry with a keyboard that has up to an 11-month battery life. -
Rest easy
Get the reassurance of a one-year limited warranty.
- HP Link-5 - keyboard - UK
- Keyboard
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Numeric Keypad
- 43.6 cm x 13.7 cm x 2.1 cm
- 560 g
- Keyboard
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
Input Device
- Wireless
- UK
- Region
- United Kingdom
- Numeric keypad
- 43.6 cm
- 13.7 cm
- 2.1 cm
- 560 g
- OS Required
- Microsoft Windows Vista / 7 / 8 / 10
- AAA type
- Required Qty
- 2
