Increase workforce productivity, enhance team communication and enable idea sharing. Simple and fast solutions that work with the tools you already use.
Pretty and pretty smart
Optimize productivity with a slim profile that conserves space and ultra-quiet scissor keys that foster focus, easy travel, and accurate typing. Get comfortable with adjustable slope, and breathe easy with a keyboard that resists minor spills. -
Ready to collaborate
Conduct virtual meetings with dedicated Skype for Business keys that control common video and call functions and have LEDs to cue incoming calls, mute, screen-sharing, and webcam usage. -
Link-5 connectivity
Work up to 30 ft (10 m) away from your PC with the Link-5 USB nano-receiver that also becomes a wireless hub for up to four additional Link-5 accessories so you can conserve USB ports on your PC. -
Stay charged
Conserve power with an On/Off switch and avoid surprises with a convenient LED that alerts you when the battery is low. Charge up while you work by plugging the keyboard's micro-USB cable into any USB port on your PC. -
World-class support
Get the reassurance of a one-year limited warranty.
- HP Collaboration - keyboard - UK
- Keyboard
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Input Device
- Wireless
- Layout
- UK
- Keys Qty
- 110
- Hot Keys Function
- Volume, answer call
- 43.3 cm x 14.1 cm x 1.18 cm
- 662.3 g
- 1-year warranty
- Designed For
- HP 245 G7, 25X G7, 340 G5; EliteBook 735 G6, 745 G6, 830 G6, 840 G6, 850 G6; EliteBook x360; EliteDesk 705 G5, 800 G5; Mobile Thin Client mt45; ProBook 430 G6, 445r G6, 44X G6, 455r G6, 45X G6, 640 G5, 650 G5; ProBook x360; ProDesk 400 G6, 600 G5; Spectre x360; ZBook 14u G6, 15 G6, 15u G6, 17 G6
- Keyboard
- Interface
- 2.4 GHz
- Wireless Receiver
Input Device
- Wireless
- Keys Qty
- 110
- Hot Keys Function
- Layout
- UK
- 43.3 cm
- 14.1 cm
- 1.18 cm
- 662.3 g
- Included Accessories
- Micro-USB to USB cable
- CSA, BSMI, cUL, CB, EMC, FCC Part 15, TELEC, cCSAus, SRRC, NCC, RCM
- OS Required
- Microsoft Windows 7, Windows 10, Windows 8.x
- Rechargeable
- Installed Qty
- 1
- Technology
- Lithium Ion
- Limited warranty - 1 year
- 0 °C
- 40 °C
- Designed For
- HP 240 G6, 245 G6, 245 G7, 250 G4, 250 G5, 250 G6, 250 G7, 255 G4, 255 G5, 255 G6, 255 G7, 340 G5, 350 G2 , HP Elite x2 1012 G2 , HP EliteBook 1030 G1, 1040 G3, 1040 G4, 1050 G1, 725 G3, 725 G4, 735 G5, 735 G6, 745 G3, 745 G4, 745 G5, 745 G6, 755 G3, 755 G4, 755 G5, 820 G3, 820 G4, 830 G5, 830 G6, 840 G3, 840 G4, 840 G5, 840 G6, 840r G4, 850 G3, 850 G4, 850 G5, 850 G6 , HP EliteBook Folio 1020 G1, 1040 G2 , HP EliteBook Revolve 810 G3 Tablet , HP EliteBook x360 1012 G2, 1030 G2, 1030 G3, 1030 G4, 1040 G5, 1040 G6, 830 G5, 830 G6 , HP EliteDesk 705 G4, 705 G5, 800 G4, 800 G5 , HP EliteOne 800 G3 , HP Mobile Thin Client mt45 , HP Pro x2 612 G2 , HP ProBook 430 G3, 430 G4, 430 G5, 430 G6, 440 G3, 440 G4, 440 G5, 440 G6, 445 G6, 445r G6, 450 G3, 450 G4, 450 G5, 450 G6, 455 G3, 455 G4, 455 G6, 455r G6, 470 G3, 470 G4, 470 G5, 640 G2, 640 G3, 640 G4, 640 G5, 645 G2, 645 G3, 645 G4, 650 G2, 650 G3, 650 G4, 650 G5, 655 G2, 655 G3 , HP ProBook x360 11 G2, 11 G3, 11 G4, 440 G1 , HP ProDesk 400 G5, 400 G6, 600 G5 , HP ProOne 400 G3, 400 G4 , HP Spectre x360 15-ch006tx , HP x2 210 G2 , HP x360 310 G2 , HP ZBook 14 G2 Mobile Workstation, 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15 G2 Mobile Workstation, 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15 G5 Mobile Workstation, 15 G6 Mobile Workstation, 15u G2 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation, 15v G5 Mobile Workstation, 17 G3 Mobile Workstation, 17 G4 Mobile Workstation, 17 G5 Mobile Workstation, 17 G6 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
