HP VH27 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: F6W3WS00 Mfr#: 3PL18AT#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£131.11 ex VAT
£157.33 inc VAT
Increase productivity on the HP VH27 68.58 cm (27") Monitor with 4-way ergonomics and a large, FHD screen.
  • Expansive screen size and crisp views
    See everything in detail with sharp 1920 x 1080 Full HD resolution, and maximize your view on a large 68.58 cm (27") diagonal screen with an IPS panel and sleek 3-sided micro-edge bezels for a virtually seamless dual-display arrangement.
  • Adjustable comfort features
    Work with personalized comfort and achieve optimal productivity through customizable tilt, swivel, pivot, and 100mm height adjustments.
  • Flexible connectivity
    Experience highly compatible connectivity with DisplayPort , HDMI, and VGA inputs for the essential ports you need and want at your convenience.
HP VH27 - LED monitor - Full HD (1080p) - 27" - TAA Compliant
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
62.15 cm x 21.8 cm x 52.52 cm
6.1 kg
English / United Kingdom
TAA Compliant
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, WHQL, CB, FCC, ICES, cTUVus, low halogen, SmartWay
1-year warranty
Display Type
Energy Class
Class A
35 kWh
24 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Pixel Per Inch
81.59
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Spanish, Dutch, Japanese
HDCP, 72% NTSC colour gamut, Mercury free, arsenic-free glass
62.15 cm x 21.8 cm x 52.52 cm - with stand
6.1 kg
VGA , HDMI (HDCP) , DisplayPort (HDCP)
Mechanical
Tilt Angle
-5/+23
Swivel Angle
360
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m
Backlight Life
30,000 hours
TAA Compliant
Security Slot Type
Kensington security slot
23 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
Without stand - width: 62.15 cm - depth: 4.6 cm - height: 37.16 cm - weight: 3.98 kg , With stand - width: 62.15 cm - depth: 21.8 cm - height: 52.52 cm - weight: 6.1 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
HP VH27 27 Bundle deal on HP VH27 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
£230.28
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 100 - 150
