HP V243 LED 24" Monitor 1920x1080 5MS
Quicklinx: C7X5WS00 Mfr#: W3R46AT#ABU
Get plenty of room to multi-task across your documents and e-mail and leave multiple windows open side by side with the HP V243 60.96 cm (24") LED Backlit Monitor, an extra-large display that's available at unbelievably low price point.
  • Business-class presentation features
    Enjoy crisp, clear views of your documents with 1920 x 1080 resolution, 5M:1 dynamic contrast ratio, and 5 ms response time. Quickly and easily connect to your devices with DVI and VGA inputs.
  • Create an efficient workspace
    Mount your HP Desktop Mini 260 directly behind the display for an integrated, affordable workspace that's perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand.
  • Designed with the environment in mind
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR certified and EPEAT Silver registered. The display also includes mercury-free display backlights and arsenic-free display glass.
HP v243 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
56.54 cm x 23.19 cm x 41.19 cm
3.46 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, TUV S, CB, CCC, PSB, FCC, KCC, ICES, KC, CECP, CEL, EPA, ISC, SEPA
Display Type
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Mercury free, arsenic-free glass
56.54 cm x 23.19 cm x 41.19 cm - with stand
3.46 kg
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-4/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.5 m
Backlight Life
30,000 hours
Input Voltage
Power Consumption (Typical)
32 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 56.54 cm - depth: 5.65 cm - height: 33.99 cm - weight: 3.02 kg , With stand - width: 56.54 cm - depth: 23.19 cm - height: 41.19 cm - weight: 3.46 kg
Sustainability Information
ENERGY STAR Certified
10 - 90% (non-condensing)
