Get plenty of room to multi-task across your documents and e-mail and leave multiple windows open side by side with the HP V243 60.96 cm (24") LED Backlit Monitor, an extra-large display that's available at unbelievably low price point.
Business-class presentation features
Enjoy crisp, clear views of your documents with 1920 x 1080 resolution, 5M:1 dynamic contrast ratio, and 5 ms response time. Quickly and easily connect to your devices with DVI and VGA inputs. -
Create an efficient workspace
Mount your HP Desktop Mini 260 directly behind the display for an integrated, affordable workspace that's perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand. -
Designed with the environment in mind
Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR certified and EPEAT Silver registered. The display also includes mercury-free display backlights and arsenic-free display glass.
- HP v243 - LED monitor - Full HD (1080p) - 24" - Smart Buy
- LED-backlit LCD monitor - 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.54 cm x 23.19 cm x 41.19 cm
- 3.46 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, TUV S, CB, CCC, PSB, FCC, KCC, ICES, KC, CECP, CEL, EPA, ISC, SEPA
- Display Type
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Mercury free, arsenic-free glass
- Black
- 56.54 cm x 23.19 cm x 41.19 cm - with stand
- 3.46 kg
- VGA , DVI-D (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -4/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x VGA cable - 1.5 m
- Backlight Life
- 30,000 hours
- Localisation
- HP Smart Buy
- Input Voltage
- Power Consumption (Typical)
- 32 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 56.54 cm - depth: 5.65 cm - height: 33.99 cm - weight: 3.02 kg , With stand - width: 56.54 cm - depth: 23.19 cm - height: 41.19 cm - weight: 3.46 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
