HP V241A 24" 1920x1080 VGA DVI-D Monitor
Quicklinx: 98Q5WS00 Mfr#: E5Z95AT#ABU
The large-screen, budget-friendly every day business display. Get an extra-large screen and quality presentation and audio features at a price point designed to fit your budget. This sleek LED monitor offers a 59,94 cm (23.6') diagonal screen, 1920 x 1080 Full HD resolution, integrated speakers, and VGA and DVI inputs-all at an unbelievably low price point. Enjoy business-class brightness, contrast, and image clarity in a design that's easy on the wallet.
  • Stylish and expansive
    Move freely around the extra-large 59,94 cm (23.6') diagonal screen that offers plenty of room to multi-task across your documents and e-mail and leave multiple windows open side by side.The slim LED footprint and internal power supply help keep your workspace tidy.
  • Business-class presentation features
    Enjoy crisp, clear wide-angle views of your content with 1920 x 1080 Full HD resolution, 3 M:1 dynamic contrast ratio, and 5 ms on/off response time. Get easy device connectivity from the VGA and DVI inputs.Hear your videoconferences and media loud and clear with integrated speakers.
  • Adjustable positioning
    Make yourself comfortable with adjustable tilt settings.
  • Designed with the environment in mind and backed by HP support
    Be a better environmental consumer with a monitor that has arsenic-free display glass and mercury-free display backlights.Get service and support from a standard, one-year limited HP warranty.
HP V241a - LED monitor - Full HD (1080p) - 23.6" - Smart Buy
LED-backlit LCD monitor - 23.6"
Stereo speakers
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
5 ms
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V
56.33 cm x 20.41 cm x 41.24 cm
4 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, MPR II
1-year warranty
Display Type
Diagonal Size
23.6"
Built-in Devices
Stereo speakers
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, On-screen Digital Controls
56.33 cm x 20.41 cm x 41.24 cm - with stand
4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
1 x audio cable , 1 x VGA cable , 1 x power cable
HP Smart Buy
Input Voltage
AC 120/230 V
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 56.33 cm - depth: 4.69 cm - height: 34.77 cm , With stand - width: 56.33 cm - depth: 20.41 cm - height: 41.24 cm - weight: 4 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80%
