HP V214a 20.7" 1920x1080 5ms HDMI VGA LED Monitor
Quicklinx: D2WJWS00 Mfr#: 1FR84AT#ABU
Enjoy impressive Full HD presentation features with integrated audio on the V214a 52.57 cm (20.7 inch) Monitor. The convenient connectivity, adaptability, and affordable price point are ideal for office use.
  • Designed with the environment in mind
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient display that is ENERGY STAR certified, EPEAT 2019 registered, and has mercury-free display backlights and arsenic-free display glass.
  • Global support
    Rest assured that your IT investment is supported by a three-year standard limited warranty. To extend your protection, select optional HP Care Pack Services.
  • Place it where you need it
    Free up valuable desk space and improve ergonomics; the integrated 100-mm standard VESA pattern supports all HP Quick Release accessories, including the HP Single Monitor Arm.
HP V214a - LED monitor - Full HD (1080p) - 20.7" - Smart Buy
LED-backlit LCD monitor - 20.7"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2385 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
48.94 cm x 19.7 cm x 36.27 cm
3 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, TUV GS, WHQL, CB, FCC, ISO 9241-307, WEEE, ICES, TUV LBL
1-year warranty
Display Type
Energy Class
Class A
28 kWh
Diagonal Size
20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2385 mm
Pixel Per Inch
108
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (On/Off)
Vertical Refresh Rate
60 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
HDCP, On-screen Digital Controls, Mercury free, 72% NTSC colour gamut
3 kg
Audio
Speakers
Output Power / Channel
1 Watt
VGA , HDMI (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+11
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.5 m , 1 x audio cable - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
19 W
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Without stand - width: 48.94 cm - depth: 4.8 cm - height: 30.06 cm - weight: 2.6 kg , With stand - width: 48.94 cm - depth: 19.7 cm - height: 36.27 cm - weight: 3 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year
5 °C
35 °C
20 - 80% (non-condensing)
D2WJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.93
D2WJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £32.96
