This work and multimedia monitor won't burden your budget. The HP V214a features a stylish, narrow profile design, compact size and an incredibly low price. Its dynamic contrast of 5,000,000:1 and a typical 5ms response means it maintains sharpness even in faster scenes of movies and games. Due to the anti-reflective surface, the experience won't be spoiled with glares, which you will appreciate on sunny days.
Designed with the environment in mind
Reduce power consumption and help lower your costs with an intelligent, energy-efficient display that is ENERGY STAR certified, EPEAT 2019 registered, and has mercury-free display backlights and arsenic-free display glass. -
Global support
Rest assured that your IT investment is supported by a three-year standard limited warranty. To extend your protection, select optional HP Care Pack Services. -
Place it where you need it
Free up valuable desk space and improve ergonomics; the integrated 100-mm standard VESA pattern supports all HP Quick Release accessories, including the HP Single Monitor Arm.
- HP V214a - LED monitor - Full HD (1080p) - 20.7"
- LED-backlit LCD monitor - 20.7"
- Energy Class
- Class A
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 19 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2385 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 48.94 cm x 19.7 cm x 36.27 cm
- 3 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, TUV GS, WHQL, CB, FCC, ISO 9241-307, WEEE, ICES, TUV LBL
- 1-year warranty
- Display Type
- Energy Class
- Class A
- 28 kWh
- Diagonal Size
- 20.7"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2385 mm
- Pixel Per Inch
- 108
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
- HDCP, On-screen Digital Controls, Low Blue Light Mode, Mercury free, arsenic-free glass, 72% NTSC colour gamut
- Black
- 48.94 cm x 19.7 cm x 36.27 cm - with stand
- 3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , HDMI (HDCP) , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+11
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x VGA cable - 1.5 m , 1 x audio cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 19 W
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 48.94 cm - depth: 4.8 cm - height: 30.06 cm - weight: 2.6 kg , With stand - width: 48.94 cm - depth: 19.7 cm - height: 36.27 cm - weight: 3 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
