HP V213a 52.57 cm (20.7") Monitor
Quicklinx: C7X4WS00 Mfr#: W3L13AT#ABU
Enjoy stunning Full HD presentation of your visuals and quality, integrated speakers with the stylish HP v213a 20.7" diagonal monitor, a budget-friendly display that's just right for everyday business.
  • Designed with the environment in mind
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR certified and EPEAT Silver registered. The display also includes mercury-free display backlights and arsenic-free display glass.
  • Global support
    Rest assured that your IT investment is supported by a one-year standard limited warranty. To extend your protection, select optional HP Care Pack Services.
HP v213a - LED monitor - Full HD (1080p) - 20.7" - Smart Buy
LED-backlit LCD monitor - 20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.238 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
48.94 cm x 19.76 cm x 36.27 cm
3 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, VCCI, CB, CCC, FCC, WEEE, CEL, EAC, ISO9241-307
1-year warranty
Display Type
Diagonal Size
20.7"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.238 mm
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, On-screen Digital Controls, Mercury free, arsenic-free glass
48.94 cm x 19.76 cm x 36.27 cm - with stand
3 kg
Audio
Speakers
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+11
Security lock slot (cable lock sold separately), detachable stand
1 x VGA cable , 1 x audio cable
HP Smart Buy
Input Voltage
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 48.94 cm - depth: 19.76 cm - height: 36.27 cm - weight: 3 kg , Without stand - width: 48.94 cm - depth: 4.8 cm - height: 30.06 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year
5 °C
35 °C
20 - 80%
