Enjoy stunning Full HD presentation of your visuals and quality, integrated speakers with the stylish HP v213a 20.7" diagonal monitor, a budget-friendly display that's just right for everyday business.
Designed with the environment in mind
Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR certified and EPEAT Silver registered. The display also includes mercury-free display backlights and arsenic-free display glass. -
Global support
Rest assured that your IT investment is supported by a one-year standard limited warranty. To extend your protection, select optional HP Care Pack Services.
- HP v213a - LED monitor - Full HD (1080p) - 20.7" - Smart Buy
- LED-backlit LCD monitor - 20.7"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.238 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 48.94 cm x 19.76 cm x 36.27 cm
- 3 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV GS, VCCI, CB, CCC, FCC, WEEE, CEL, EAC, ISO9241-307
- 1-year warranty
- Display Type
- Diagonal Size
- 20.7"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.238 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Response Time
- 5 ms (On/Off)
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, On-screen Digital Controls, Mercury free, arsenic-free glass
- Black
- 48.94 cm x 19.76 cm x 36.27 cm - with stand
- 3 kg
Audio
- Speakers
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+11
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Localisation
- HP Smart Buy
- Input Voltage
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 48.94 cm - depth: 19.76 cm - height: 36.27 cm - weight: 3 kg , Without stand - width: 48.94 cm - depth: 4.8 cm - height: 30.06 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 1 year
- 5 °C
- 35 °C
- 20 - 80%
