Get quality presentation features at a price point that doesn't break the bank with the HP V197 47 cm (18.5") Monitor, a sleek, thin-profile monitor in a compact, space-saving screen size with an unbelievably low price point.
Business-class presentation features
Enjoy crisp, clear views of your documents and e-mail with 1366 x 768 resolution, 5M:1 dynamic contrast ratio, and 5 ms response time on an 47 cm (18.5") inch diagonal screen. Quickly and easily connect to your devices with DVI and VGA inputs. -
Create an efficient workspace
Mount your HP Desktop Mini 260 directly behind the display for an integrated, affordable all-in-one that's perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand. -
Designed with the environment in mind
Reduce power consumption and help lower your costs with an intelligent, energy-efficient design that is ENERGY STAR certified and EPEAT Silver registered. The display also includes mercury-free display backlights and arsenic-free display glass.
- HP v197 - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Input Connectors
- DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 44.14 cm x 21.81 cm x 33.86 cm
- 2.6 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV, GS, CB, CCC
- Display Type
- Diagonal Size
- 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Response Time
- 5 ms (On/Off)
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- HDCP, Mercury free, arsenic-free glass
- Black
- 44.14 cm x 21.81 cm x 33.86 cm - with stand
- 2.6 kg
KVM
- KVM switch
- VGA (HDCP) , DVI-D (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- Cables Included
- 1 x VGA cable
- Localisation
- Input Voltage
- Power Consumption (Typical)
- 17 watt
- Power Consumption Stand by
- 0.5 watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 44.14 cm - depth: 21.81 cm - height: 33.86 cm - weight: 2.6 kg , Without stand - width: 44.14 cm - depth: 4.54 cm - height: 27.77 cm
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80%
