Get quality presentation features at a price point that doesn't break the bank with the HP V194 18.5-inch Monitor, a sleek, thin-profile monitor in a compact, space-saving screen size with an unbelievably low price point.
Get comfortable
Customize your display's position with adjustable tilt settings and viewing angles. -
World-class support
Rest assured that your IT investment is supported by a three-year standard limited warranty. To extend your protection, select optional HP Care Packs.
- HP V194 - LED monitor - 18.5" - Smart Buy
- LED-backlit LCD monitor - 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V
- Black
- 44.14 cm x 21.81 cm x 33.86 cm
- 2.6 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, TUV, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ETL, KCC, ICES, KC, CECP, CEL, EPA, ISC, SEPA
- 1-year warranty
- Display Type
- Diagonal Size
- 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Response Time
- 5 ms (On/Off)
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Mercury free, arsenic free
- Black
- 44.14 cm x 21.81 cm x 33.86 cm - with stand
- 2.6 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- Cables Included
- 1 x VGA cable
- Localisation
- HP Smart Buy
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100-240 V
- Power Consumption (Typical)
- 15 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 44.14 cm - depth: 4.54 cm - height: 27.77 cm , With stand - width: 44.14 cm - depth: 21.81 cm - height: 33.86 cm - weight: 2.6 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 1 year
- 5 °C
- 35 °C
- 20 - 80%
