The HP PUSB Thermal Receipt Printer is designed for retail environments with its durable design and print performance. Its compact size also makes it perfect for space-constrained locations.
- HP Single Station Thermal Receipt Printer - receipt printer - two-colour (monochrome) - direct thermal
- Printer Type
- Receipt printer - direct thermal - two-colour (monochrome)
- 1.34 kg
- Max Media Size
- Roll (0.8 cm)
- Print Speed
- Up to 74 lines/sec - monochrome , Up to 44 lines/sec - two-colour
- Max Resolution (B&W)
- 203 dpi
- Interface
- PoweredUSB
- RAM Installed (Max)
- 512 KB
- Flash Memory Installed (Max)
- 4 MB
- Media Type
- Thermal paper
- System Requirements
- Microsoft Windows XP Professional, Microsoft Windows Embedded for Point of Service, Microsoft Windows Vista Business
- 13.4 cm x 18.4 cm x 14.4 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- PoweredUSB
- 203 dpi
- Columns
- 56, 44
RAM
- 512 KB
Flash Memory
- Flash Memory
- 4 MB
Media Handling
- Media Type
- Thermal paper
- Max Media Size
- Roll (0.8 cm)
- Media Sizes
- Roll (0.8 cm)
- Media Feeders
- 1 x manual - Roll (0.8 cm)
- Connections
- 1 x PoweredUSB
- FCC Class B certified, VCCI, C-Tick, EN 60950, ICES-003, UL 1950, CSA 22.2 No. 950, WHQL, MITI, CCC, MIC, FCC, RoHS, WEEE
- OS Required
- 13.4 cm
- 18.4 cm
- 14.4 cm
- 1.34 kg
