Plug right in and get ready to speak and hear clearly all day. With noise-cancelling, comfortable design, and easy adjustment, your sound comfort will carry you from call to call without interference or frustration.
Control the call
Hop on any call with ease. The flexible boom mic blocks the background noise to keep your call focused. The in-line volume control and mute keeps you in control of your environment. -
Snug and comfortable
These durable vegan leather earcups are designed for all-day comfort. Just adjust the head strap to be perfectly snug so you can hop on and off calls all day without soreness. -
Simple USB-A connection
A simple USB-A plug will have you on the call in seconds with a connection that won't glitch out or lose power.
 - HP G2 - headset
- Product Type
 - Headset - wired - USB
- Recommended Use
 - Computer
- Localisation
 - English / United Kingdom
- Headphones Form Factor
 - On-ear
- Connectivity Technology
 - Wired
- Sound Output Mode
 - Stereo
- Audio Specifications
 - Sensitivity 120 dB
- Impedance
 - 64 Ohm
- Microphone
 - Boom
- Microphone Noise Cancelling
- Controls
 - Volume, microphone on/mute, play/pause
 - 1-year warranty
- Product Type
 - 16.5 cm
 - 5 cm
 - 13 cm
 - 90 g
- Recommended Use
 - Computer
- Localisation
Audio Output
 - On-ear
- Headphones Cup Type
 - Closed
 - Wired
- Sound Output Mode
 - Stereo
- Sensitivity
 - 120 dB
- Impedance
 - 64 Ohm
- In-Cord Volume Control
- Adjustable Headband
Microphone
 - Boom
- Form Factor
 - Headset microphone
 - Wired
- Sensitivity
 - -38 dB
- Frequency Response
 - 100 - 10000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
 - Headset (USB Type-A)
- Cable Details
 - Headset cable
 - Limited warranty - 1 year
- Shipping Width
 - 17 cm
- Shipping Depth
 - 14.4 cm
- Shipping Height
 - 5.4 cm
- Shipping Weight
 - 210 g
