HP USB-C To VGA Adapter
Quicklinx: C7HQWS00 Mfr#: N9K76AA
Hurry, only 1 left in stock!
£29.31 ex VAT
£35.17 inc VAT
Drive your notebook or tablet's video content to an external display, TV, or projector with the HP USB-C to VGA Adapter.
  • One-cable connectivity
    Plug the adapter into your tablet or notebook's USB-C port and send your work to a monitor, projector or TV through the VGA port.
  • Take it to go
    Store the small adapter with you in your device's carrying case for quick projection wherever you work.
  • World-class support
    Rest easy with a one-year limited warranty.
HP - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
2560 x 1600
VGA
2.55 cm 1.3 cm
Length
15 cm
Enclosure Colour
1-year warranty
HP 245 G7, 340S G7; Chromebook 14 G6; Chromebook Enterprise x360; Chromebook x360; Elite Slice G2; Elite Dragonfly; Elite x2; EliteBook 735 G6, 745 G6; EliteBook x360; EliteDesk 800 G5; Mobile Thin Client mt45; ProBook 430 G7, 440 G7, 450 G7; ProBook x360; ProDesk 600 G5; ZBook 15 G6, 17 G6
Bus Type
USB-C
Max Resolution
2560 x 1600
VGA
High Bit Rate 2
Microsoft Windows 7 (32/64 bits) SP1, Windows 8, Windows 10
RoHS, WEEE, REACH
2.55 cm
1.3 cm
Length
15 cm
23.9 g
Enclosure Colour
Limited warranty - 1 year
HP 245 G7, 340S G7 , HP Chromebook 11 G7, 11A G6, 13 G1, 14 G6, 14A G5 , HP Chromebook Enterprise x360 14E G1 , HP Chromebook x360 11 G2, 11 G3, 14 G1 , HP Chromebox G2 , HP Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite, Slice for Meeting Rooms G2 for Skype Room Systems, Slice G2 Audio Ready with Microsoft Teams Room, Slice G2 with Intel Unite, Slice G2 with Microsoft Teams Room , HP Elite Dragonfly , HP Elite x2 1012 G1, 1012 G2, 1013 G3, G4 , HP Elite x3 , HP EliteBook 1040 G3, 1040 G4, 1050 G1, 735 G5, 735 G6, 745 G5, 745 G6, 755 G5, 830 G5, 840 G5, 840 G6, 840r G4, 850 G5, 850 G6 , HP EliteBook Folio G1 , HP EliteBook x360 1012 G2, 1020 G2, 1030 G2, 1030 G3, 1030 G4, 1040 G5, 1040 G6, 830 G5, 830 G6 , HP EliteDesk 800 G4, 800 G5 , HP EliteOne 800 G5 , HP Mobile Thin Client mt45 , HP Pro Tablet 608 G1 , HP Pro x2 612 G2 , HP ProBook 430 G5, 430 G6, 430 G7, 440 G5, 440 G6, 440 G7, 450 G5, 450 G6, 450 G7, 455 G5, 470 G5, 640 G4, 640 G5, 645 G4, 650 G4, 650 G5 , HP ProBook x360 11 G2, 11 G3, 11 G4, 11 G5, 440 G1 , HP ProDesk 600 G3, 600 G5 , HP Spectre Pro 13 G1 , HP Spectre x360 15-ch006tx , HP ZBook 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15 G5 Mobile Workstation, 15 G6 Mobile Workstation, 15u G4 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation, 15v G5 Mobile Workstation, 17 G3 Mobile Workstation, 17 G4 Mobile Workstation, 17 G5 Mobile Workstation, 17 G6 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Brand: HP
Price Range Ex VAT: 0 - 50
