Optimize your workspace with easy connectivity to your frequently-used accessories in the office and on the road. Convert your notebook or tablet's USB-C port to a portable, lightweight USB hub and enable simultaneous connections to up to three USB accessories with the HP USB-C to USB-A Hub.
No software required
Simply plug the attached USB-C cable into any available USB-C port on your device, and the hub is ready for your USB accessories. -
Keep the accessories you trust
Charge your cell phone with the hub's USB 3.0 charging port and use the other two USB ports to connect to your external storage, keyboard, mouse, headset, optical drive, and more. -
Take it with you
Wrap the attached USB cable around the hub for convenient transport or storage alongside your tablet or notebook. -
Rest easy
Get the reassurance of a one-year limited warranty.
- HP USB-C to USB-A - hub - 3 ports
- Hub - 3 ports
- Subtype
- USB
- Ports
- 3 x SuperSpeed USB 3.0
- USB 2.0, USB 3.0
- 1-year warranty
- Designed For
- Elite c640 G3 Chromebook Enterprise; Pavilion Aero Laptop 13-be2075ng
- Hub - 3 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB 2.0, USB 3.0
- 3 x USB 3.0 Type A , 1 x USB-C Type C
- Limited warranty - 1 year
- Designed For
- HP Elite c640 G3 Chromebook Enterprise , HP Pavilion Aero Laptop 13-be2075ng
