HP USB-C to RJ45 Adapter G2
Quicklinx: H10FWS00 Mfr#: 4Z527AA
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Type: Network adapter
Hurry, only 2 left in stock!
£13.09 ex VAT
£15.70 inc VAT
Connect your USB-C device to the Ethernet with this easy-to-carry, plug-and-play Ethernet adapter. Get the fast Internet speed of a wired Ethernet connection for fast and reliable streaming and downloads.
  • High speed support
    Ethernet connection supports speeds up to 1 Gbps, so you can stream and work with ease.
  • Perfectly portable
    The lightweight design is easy to carry, for wherever you have access to the Ethernet.
  • Enables network manageability
    Help IT secure and remotely manage your laptop fleet with advanced network manageability features through a wired Internet connection enabled by this adapter.
HP USB-C to RJ45 Adapter G2 - network adapter - USB-C - Gigabit Ethernet x 1
Network adapter
External
Interface (Bus) Type
USB-C
Ports
18 cm x 2.06 cm x 1.65 cm
20 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Windows 10, Windows 11
1-year warranty
Victus by HP Laptop 15, 16; HP 250 G9; Chromebook x360; ENVY Laptop 16, 17; ENVY x360 Laptop; Fortis 11 G9; Laptop 14, 15, 15s, 17; Pavilion x360 Laptop; Spectre x360 Laptop
Network adapter
External
USB-C
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
PXE boot, WOL
1 x 1000Base-T - RJ-45 - female
18 cm
2.06 cm
1.65 cm
20 g
Limited warranty - 1 year
Victus by HP Laptop 15-fb0000nm, 15-fb0012ns, 15-fb0026nm, 16-d0026nb, 16-d1025nl, 16-d1034ns, 16-e0001ny, 16-e0021nl, 16-e0022nl, 16-e0054nl, 16-e0314nf, 16-e1003ny, 16-e1007nq, 16-e1010ca, 16-e1020ca, 16-e1900ng , HP 250 G9 Notebook , HP Chromebook x360 14a-ca0061nf, 14a-ca0097nr , HP ENVY Laptop 16-h0720nz, 16-h0950nz, 17-ch0121nf, 17-ch1000nl, 17-ch1002nq, 17-ch1009nq, 17-ch1011nq, 17-ch1013nq , HP ENVY x360 Laptop 15-ey0365nd, 15-ey0404nz , HP Fortis 11 G9 Q Chromebook , HP Laptop 14-dq3210ca, 14-fq0200ca, 14-fq0210ca, 15-dw0083wm, 15-dw1016nq, 15-dw1024nk, 15-dw1025nk, 15-dw3003nq, 15-dw3052nk, 15-dw4030nm, 15s-eq1018ny, 15s-eq2049np, 15s-eq2050np, 15s-eq2056nb, 15s-eq2083nl, 15s-eq2083ns, 15s-eq3005nl, 15s-eq3016nl, 15s-eq3017nl, 15s-eq3020nl, 15s-eq3621nd, 15s-fq0071nl, 15s-fq0072nl, 15s-fq2022nh, 15s-fq2042np, 15s-fq2119nl, 15s-fq4025nl, 15s-fq4029nl, 15s-fq4030nl, 15s-fq4033nl, 15s-fq4054nb, 15s-fq5013ny, 15s-fq5016ny, 17-cn0012ns, 17-cn0210nd, 17-cn2004nm, 17-cn2048nm , HP Pavilion x360 Laptop 14-ek0005nm, 15-er1003nm , HP Spectre x360 Laptop 16-f0035nn, 16-f1710nz, 16-f1740nz
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Brand: HP
