Connect your USB-C device to the Ethernet with this easy-to-carry, plug-and-play Ethernet adapter. Get the fast Internet speed of a wired Ethernet connection for fast and reliable streaming and downloads.
                High speed supportEthernet connection supports speeds up to 1 Gbps, so you can stream and work with ease.
                Perfectly portableThe lightweight design is easy to carry, for wherever you have access to the Ethernet.
                Enables network manageabilityHelp IT secure and remotely manage your laptop fleet with advanced network manageability features through a wired Internet connection enabled by this adapter.
- HP USB-C to RJ45 Adapter G2 - network adapter - USB-C - Gigabit Ethernet x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB-C
- Ports
- 18 cm x 2.06 cm x 1.65 cm
- 20 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- System Requirements
- Windows 10, Windows 11
- 1-year warranty
- Designed For
- Victus by HP Laptop 15, 16; HP 250 G9; Chromebook x360; ENVY Laptop 16, 17; ENVY x360 Laptop; Fortis 11 G9; Laptop 14, 15, 15s, 17; Pavilion x360 Laptop; Spectre x360 Laptop
- Network adapter
- Form Factor
- External
- USB-C
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- PXE boot, WOL
- 1 x 1000Base-T - RJ-45 - female
- OS Required
- 18 cm
- 2.06 cm
- 1.65 cm
- 20 g
- Limited warranty - 1 year
- Designed For
- Victus by HP Laptop 15-fb0000nm, 15-fb0012ns, 15-fb0026nm, 16-d0026nb, 16-d1025nl, 16-d1034ns, 16-e0001ny, 16-e0021nl, 16-e0022nl, 16-e0054nl, 16-e0314nf, 16-e1003ny, 16-e1007nq, 16-e1010ca, 16-e1020ca, 16-e1900ng , HP 250 G9 Notebook , HP Chromebook x360 14a-ca0061nf, 14a-ca0097nr , HP ENVY Laptop 16-h0720nz, 16-h0950nz, 17-ch0121nf, 17-ch1000nl, 17-ch1002nq, 17-ch1009nq, 17-ch1011nq, 17-ch1013nq , HP ENVY x360 Laptop 15-ey0365nd, 15-ey0404nz , HP Fortis 11 G9 Q Chromebook , HP Laptop 14-dq3210ca, 14-fq0200ca, 14-fq0210ca, 15-dw0083wm, 15-dw1016nq, 15-dw1024nk, 15-dw1025nk, 15-dw3003nq, 15-dw3052nk, 15-dw4030nm, 15s-eq1018ny, 15s-eq2049np, 15s-eq2050np, 15s-eq2056nb, 15s-eq2083nl, 15s-eq2083ns, 15s-eq3005nl, 15s-eq3016nl, 15s-eq3017nl, 15s-eq3020nl, 15s-eq3621nd, 15s-fq0071nl, 15s-fq0072nl, 15s-fq2022nh, 15s-fq2042np, 15s-fq2119nl, 15s-fq4025nl, 15s-fq4029nl, 15s-fq4030nl, 15s-fq4033nl, 15s-fq4054nb, 15s-fq5013ny, 15s-fq5016ny, 17-cn0012ns, 17-cn0210nd, 17-cn2004nm, 17-cn2048nm , HP Pavilion x360 Laptop 14-ek0005nm, 15-er1003nm , HP Spectre x360 Laptop 16-f0035nn, 16-f1710nz, 16-f1740nz
