HP USB-C to DisplayPort Adapter
Quicklinx: F6ZMWS00 Mfr#: N9K78AA
22 in stock
£30.00 ex VAT
£36.00 inc VAT
Put your notebook or tablet's high-definition video content up on the big screen with the HP USB-C to DP Adapter, which enables connection to an external display, TV or projector.
  • Show and tell
    Connect the adapter to your tablet or notebook's USB-C port and broadcast to a monitor, projector or TV through the DisplayPort connection.
  • Pack and go
    Take the small adapter with you in your device's carrying case for quick projection wherever you work.
  • World-class support
    Rest easy with a one-year limited warranty.
HP - external video adapter
External video adapter
Bus Type
USB-C
DisplayPort
2.36 cm 1.52 cm
Length
18 cm
HP 340S G7; Chromebook 14 G6; Elite Slice G2; Elite Dragonfly; Elite x2; EliteBook 735 G6, 745 G6, 840 G6, 850 G6; EliteBook x360; EliteDesk 800 G5; EliteOne 800 G5; Mobile Thin Client mt45; ProBook 430 G7, 440 G7, 450 G7, 640 G5, 650 G5; ProBook x360; ProDesk 600 G5; ZBook 15 G6, 15u G6, 17 G6
Bus Type
USB-C
DisplayPort
2.36 cm
1.52 cm
Length
18 cm
32.3 g
HP 340S G7 , HP Chromebook 11A G6, 13 G1, 14 G6 , HP Chromebox G2 , HP Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite, Slice for Meeting Rooms G2 for Skype Room Systems, Slice G2 Audio Ready with Microsoft Teams Room, Slice G2 with Intel Unite, Slice G2 with Microsoft Teams Room , HP Elite Dragonfly , HP Elite x2 1012 G1, 1012 G2, 1013 G3, G4 , HP EliteBook 1030 G1, 1040 G4, 1050 G1, 735 G5, 735 G6, 745 G5, 745 G6, 755 G5, 830 G5, 840 G5, 840 G6, 840r G4, 850 G5, 850 G6 , HP EliteBook Folio G1 , HP EliteBook x360 1012 G2, 1020 G2, 1030 G2, 1030 G3, 1030 G4, 1040 G5, 1040 G6, 830 G5, 830 G6 , HP EliteDesk 800 G4, 800 G5 , HP EliteOne 800 G5 , HP Mobile Thin Client mt45 , HP Pro Tablet 608 G1 , HP Pro x2 612 G2 , HP ProBook 430 G5, 430 G6, 430 G7, 440 G5, 440 G6, 440 G7, 450 G5, 450 G6, 450 G7, 455 G5, 470 G5, 640 G4, 640 G5, 645 G4, 650 G4, 650 G5 , HP ProBook x360 11 G2, 11 G3, 11 G4, 11 G5, 440 G1 , HP ProDesk 400 G5, 600 G3, 600 G4, 600 G5 , HP Spectre Pro 13 G1 , HP Spectre x360 15-ch006tx , HP ZBook 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15 G5 Mobile Workstation, 15 G6 Mobile Workstation, 15u G4 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation, 15v G5 Mobile Workstation, 17 G3 Mobile Workstation, 17 G4 Mobile Workstation, 17 G5 Mobile Workstation, 17 G6 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Brand: HP
Price Range Ex VAT: 0 - 50
